Type for an interval in a persistent diagram or barcode. Stores the birth, death and dimension of the interval. It can be used as a tuple with get/std::get (birth, death and dimension in this order), std::tuple_element and std::tuple_size, as well as structured binding.
More...
#include <gudhi/persistence_interval.h>
| static constexpr Event_value | inf |
| | Stores the infinity value for birth and death events. Its value depends on the template parameter Event_value: More...
template<typename Dimension, typename Event_value>
class Gudhi::persistence_matrix::Persistence_interval< Dimension, Event_value >
- Template Parameters
| Dimension | Type of the dimension value. |
| Event_value | Type of the birth and death value. |
- Examples
- example_zigzag_filtration_as_input_loop.cpp.
◆ Persistence_interval()
template<typename Dimension , typename Event_value >
Constructor.
- Parameters
| birth | Birth value of the cycle. Default value: inf. |
| death | Death value of the cycle. Default value: inf. |
| dim | Dimension of the cycle. Default value: -1. |
◆ get() [1/4]
template<std::size_t I>
Specialization of get for Gudhi::persistence_matrix::Persistence_interval.
| I | Index of the value to return: 0 for the birth value, 1 for the death value and 2 for the dimension. |
- Returns
- Either the birth value if
I == 0, the death value if I == 1 or the dimension if I == 2.
◆ get() [2/4]
- Returns
◆ get() [3/4]
- Returns
◆ get() [4/4]
- Returns
◆ operator<<
| std::ostream & operator<< |
std::ostream & |
stream, |
const Persistence_interval< Dimension, Event_value > & |
interval |
friend |
operator<<
- Parameters
| stream | outstream |
| interval | interval to stream |
◆ birth
◆ death
◆ dim
◆ inf
Initial value:= std::numeric_limits<Event_value>::has_infinity
? std::numeric_limits<Event_value>::infinity()
: static_cast<Event_value>(-1)
- if
Event_value has a native infinity value, it takes this value,
- otherwise, if
Event_value is a signed type, it takes value -1,
- otherwise, if
Event_value is a unsigned type, it takes the maximal possible value.
Is also used as default value for birth and death attributes when not initialized.
The documentation for this class was generated from the following file:
