| template<typename Distance , typename Point_range , typename PointOutputIterator , typename DistanceOutputIterator = Null_output_iterator> |
| void | Gudhi::subsampling::choose_n_farthest_points (Distance dist, Point_range const &input_pts, std::size_t final_size, std::size_t starting_point, PointOutputIterator output_it, DistanceOutputIterator dist_it={}) |
| | Subsample by an iterative, greedy strategy. More...
| void | Gudhi::subsampling::choose_n_farthest_points_metric (Distance dist_, Point_range const &input_pts, std::size_t final_size, std::size_t starting_point, PointOutputIterator output_it, DistanceOutputIterator dist_it={}) |
| template<typename Point_container , typename OutputIterator > |
| void | Gudhi::subsampling::pick_n_random_points (Point_container const &points, std::size_t final_size, OutputIterator output_it) |
| | Subsample a point set by picking random vertices. More...
| template<typename Kernel , typename Point_range , typename OutputIterator > |
| void | Gudhi::subsampling::sparsify_point_set (const Kernel &k, Point_range const &input_pts, typename Kernel::FT min_squared_dist, OutputIterator output_it) |
| | Outputs a subset of the input points so that the squared distance between any two points is greater than min_squared_dist. More...
- Author
- Clément Jamin, Siargey Kachanovich, Marc Glisse
Introduction
This Gudhi component offers methods to subsample a set of points.
Example: sparsify_point_set
This example outputs a subset of the input points so that the squared distance between any two points is greater than or equal to 0.4.
#include <gudhi/sparsify_point_set.h>
#include <CGAL/Epick_d.h>
#include <CGAL/Random.h>
#include <iostream>
#include <vector>
#include <iterator>
int main(void) {
typedef CGAL::Epick_d<CGAL::Dimension_tag<4> > K;
typedef typename K::Point_d Point_d;
CGAL::Random rd;
std::vector<Point_d> points;
for (int i = 0; i < 500; ++i)
points.push_back(Point_d(rd.get_double(-1., 1), rd.get_double(-1., 1),
rd.get_double(-1., 1), rd.get_double(-1., 1)));
K k;
std::vector<Point_d> results;
std::clog << "Before sparsification: " << points.size() << " points.\n";
std::clog << "After sparsification: " << results.size() << " points.\n";
return 0;
void sparsify_point_set(const Kernel &k, Point_range const &input_pts, typename Kernel::FT min_squared_dist, OutputIterator output_it)
Outputs a subset of the input points so that the squared distance between any two points is greater t...
Definition: sparsify_point_set.h:50
Example: choose_n_farthest_points
This example outputs a subset of 100 points obtained by González algorithm, starting with a random point, and greedily adding the point farthest from those already picked.
#include <gudhi/choose_n_farthest_points.h>
#include <iostream>
#include <vector>
#include <iterator>
int main(void) {
CGAL::Random rd;
K k;
std::back_inserter(results));
return 0;
void choose_n_farthest_points(Distance dist, Point_range const &input_pts, std::size_t final_size, std::size_t starting_point, PointOutputIterator output_it, DistanceOutputIterator dist_it={})
Definition: choose_n_farthest_points.h:75
@ random_starting_point
Definition: choose_n_farthest_points.h:43
There is an alternative version choose_n_farthest_points_metric() with the same syntax, which can be faster in many cases.
Example: pick_n_random_points
This example outputs a subset of 100 points picked randomly.
#include <gudhi/pick_n_random_points.h>
#include <iostream>
#include <vector>
#include <iterator>
int main(void) {
CGAL::Random rd;
K k;
return 0;
void pick_n_random_points(Point_container const &points, std::size_t final_size, OutputIterator output_it)
Definition: pick_n_random_points.h:42
◆ anonymous enum
| anonymous enum : std::size_t |
| Enumerator |
| random_starting_point | Argument for choose_n_farthest_points to indicate that the starting point should be picked randomly.
◆ choose_n_farthest_points()
| void Gudhi::subsampling::choose_n_farthest_points |
Distance |
dist, |
Point_range const & |
input_pts, |
std::size_t |
final_size, |
std::size_t |
starting_point, |
PointOutputIterator |
output_it, |
DistanceOutputIterator |
dist_it = {} |
The algorithm starts with the landmark starting point or, if starting point==random_starting_point, with a landmark chosen randomly from the point set. At each iteration, it finds the point farthest from the set of current landmarks, outputs this distance, and promotes the point to landmark. It stops after finding final_size landmarks.
- Template Parameters
| Distance | must provide an operator() that takes 2 points (value type of the range) and returns their distance (or some more general proximity measure) as a double. |
| Point_range | Random access range of points. |
| PointOutputIterator | Output iterator whose value type is the point type. |
| DistanceOutputIterator | Output iterator for distances. |
- Parameters
| [in] | dist | Distance function. |
| [in] | input_pts | The input points. |
| [in] | final_size | The size of the subsample to compute (reduced to the number of input points if final_size is larger). |
| [in] | starting_point | The seed in the farthest point algorithm. |
| [out] | output_it | The output iterator where landmarks are written. |
| [out] | dist_it | The optional output iterator where the distance from a landmark to the previous landmarks is written. |
- Warning
- Older versions of this function took a CGAL kernel as argument. Users need to replace
k with k.squared_distance_d_object() in the first argument of every call to choose_n_farthest_points.
- Examples
- example_choose_n_farthest_points.cpp, example_custom_distance.cpp, example_strong_witness_complex_off.cpp, example_witness_complex_off.cpp, example_witness_complex_sphere.cpp, strong_witness_persistence.cpp, and weak_witness_persistence.cpp.
◆ choose_n_farthest_points_metric()
| void Gudhi::subsampling::choose_n_farthest_points_metric |
Distance |
dist_, |
input_pts, |
std::size_t |
final_size, |
std::size_t |
starting_point, |
output_it, |
dist_it = {} |
This computes the same thing as choose_n_farthest_points(), but relies on the triangle inequality to reduce the amount of computation when the doubling dimension and spread are small. In the worst case, this can be much slower than choose_n_farthest_points() though. See [20] and its associated video for details about this algorithm.
| Distance | must provide an operator() that takes 2 points (value type of the range) and returns their distance as a double. It must be a true metric (not squared Euclidean), the algorithm relies on the triangle inequality. |
- Parameters
| [in] | dist_ | Distance function. |
◆ pick_n_random_points()
| void Gudhi::subsampling::pick_n_random_points |
Point_container const & |
points, |
std::size_t |
final_size, |
OutputIterator |
output_it |
It chooses final_size distinct points from a random access range points and outputs them to the output iterator output_it. Point_container::iterator should be ValueSwappable and RandomAccessIterator.
- Examples
- example_pick_n_random_points.cpp.
◆ sparsify_point_set()
| void Gudhi::subsampling::sparsify_point_set |
const Kernel & |
k, |
input_pts, |
typename Kernel::FT |
min_squared_dist, |
OutputIterator |
output_it |
| Kernel | must be a model of the SearchTraits concept, such as the CGAL::Epick_d class, which can be static if you know the ambiant dimension at compile-time, or dynamic if you don't. |
| Point_range | Range whose value type is Kernel::Point_d. It must provide random-access via operator[] and the points should be stored contiguously in memory. |
| OutputIterator | Output iterator whose value type is Kernel::Point_d. |
- Parameters
| [in] | k | A kernel object. |
| [in] | input_pts | Const reference to the input points. |
| [in] | min_squared_dist | Minimum squared distance separating the output points. |
| [out] | output_it | The output iterator. |
- Examples
- example_sparsify_point_set.cpp, and example_with_perturb.cpp.
