Class managing the row access for the inheriting matrix. More...
#include <gudhi/Persistence_matrix/matrix_row_access.h>
Public Member Functions | |
| Matrix_row_access () | |
| Default constructor. | |
| Matrix_row_access (unsigned int numberOfRows) | |
| Constructor reserving space for the given number of rows. More... | |
| Matrix_row_access (const Matrix_row_access &toCopy) | |
| Copy constructor. More... | |
| Matrix_row_access (Matrix_row_access &&other) noexcept | |
| Move constructor. More... | |
| ~Matrix_row_access () | |
| Destructor. | |
| Row & | get_row (ID_index rowIndex) |
| Returns the row at the given row index. The type of the row depends on the chosen options, see PersistenceMatrixOptions::has_intrusive_rows. More... | |
| const Row & | get_row (ID_index rowIndex) const |
| void | erase_empty_row (ID_index rowIndex) |
| Only available if PersistenceMatrixOptions::has_removable_rows is true. Removes the given row from the row container if the row exists and is empty. More... | |
| Matrix_row_access & | operator= (const Matrix_row_access &other) |
| Assign operator. | |
Friends | |
| void | swap (Matrix_row_access &matrix1, Matrix_row_access &matrix2) |
| Swap operator. | |
| Row | Either boost::intrusive::list<Matrix_entry,...> if PersistenceMatrixOptions::has_intrusive_rows is true, or std::set<Matrix_entry, RowEntryComp> otherwise. |
| Row_container | Either std::map<Index,Row> if PersistenceMatrixOptions::has_removable_rows is true, or std::vector<Row> otherwise. |
| has_removable_rows | Value of PersistenceMatrixOptions::has_removable_rows. |
| ID_index | IDIdx index type. |
inline |
Has only an effect if PersistenceMatrixOptions::has_removable_rows is false.
| numberOfRows | Number of rows to reserve space for. |
inline |
Copy constructor.
| toCopy | Matrix to copy. |
inlinenoexcept |
Move constructor.
| other | Matrix to move. |
inline |
| rowIndex | Row index of the row to remove. |
inline |
| rowIndex | Row index of the row to return: IDIdx for chain matrices or updated IDIdx for boundary matrices if swaps occurred. |
inline |
