Class managing the vine swaps for Chain_matrix. More...
#include <gudhi/Persistence_matrix/chain_vine_swap.h>
Public Types | |
| using | Index = typename Master_matrix::Index |
| using | ID_index = typename Master_matrix::ID_index |
| using | Pos_index = typename Master_matrix::Pos_index |
| using | Column_container = typename Master_matrix::Column_container |
| using | Column = typename Master_matrix::Column |
| typedef bool(* | EventCompFuncPointer) (Pos_index, Pos_index) |
Public Member Functions | |
| Chain_vine_swap () | |
| Default constructor. Only available if PersistenceMatrixOptions::has_column_pairings is true. | |
| Chain_vine_swap (std::function< bool(Pos_index, Pos_index)> birthComparator, std::function< bool(Pos_index, Pos_index)> deathComparator=_no_G_death_comparator) | |
| Constructor storing the given comparators. More... | |
| Chain_vine_swap (const Chain_vine_swap &matrixToCopy) | |
| Copy constructor. More... | |
| Chain_vine_swap (Chain_vine_swap &&other) noexcept | |
| Move constructor. More... | |
| Index | vine_swap_with_z_eq_1_case (Index columnIndex1, Index columnIndex2) |
| Does the same than vine_swap, but assumes that the swap is non trivial and therefore skips a part of the case study. More... | |
| Index | vine_swap (Index columnIndex1, Index columnIndex2) |
| Does a vine swap between two cells which are consecutive in the filtration. Roughly, if \( F \) is the current filtration represented by the matrix, the method modifies the matrix such that the new state corresponds to a valid state for the filtration \( F' \) equal to \( F \) but with the two given cells at swapped positions. Of course, the two cells should not have a face/coface relation which each other ; \( F' \) has to be a valid filtration. See [21] for more information about vine and vineyards. More... | |
| Chain_vine_swap & | operator= (Chain_vine_swap other) |
| Assign operator. | |
Friends | |
| void | swap (Chain_vine_swap &swap1, Chain_vine_swap &swap2) |
| Swap operator. | |
| Master_matrix | An instantiation of Matrix from which all types and options are deduced. |
| using Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::Column = typename Master_matrix::Column |
Column type.
| using Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::Column_container = typename Master_matrix::Column_container |
Column container type.
| typedef bool(* Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::EventCompFuncPointer) (Pos_index, Pos_index) |
Pointer type for birth/death comparators.
| using Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::ID_index = typename Master_matrix::ID_index |
IDIdx index type.
| using Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::Index = typename Master_matrix::Index |
MatIdx index type.
| using Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::Pos_index = typename Master_matrix::Pos_index |
PosIdx index type.
inline |
| birthComparator | Method taking two PosIdx indices as input and returning true if and only if the birth associated to the first position is strictly less than birth associated to the second one with respect to some self defined order. It is used while swapping two unpaired or two negative columns. |
| deathComparator | Method taking two PosIdx indices as input and returning true if and only if the death associated to the first position is strictly less than death associated to the second one with respect to some self defined order. It is used while swapping two positive but paired columns. Default value: _no_G_death_comparator. |
inline |
Copy constructor.
| matrixToCopy | Matrix to copy. |
inlinenoexcept |
Move constructor.
| other | Matrix to move. |
inline |
inline |
