Gudhi::Persistence_interval_common< Filtration_type, Coefficient_field > Class Template Reference
#include <include/gudhi/writing_persistence_to_file.h>
Public Member Functions
 Persistence_interval_common (Filtration_type birth, Filtration_type death)
 Persistence_interval_common (Filtration_type birth, Filtration_type death, unsigned dim)
 Persistence_interval_common (Filtration_type birth, Filtration_type death, unsigned dim, Coefficient_field field)
bool operator== (const Persistence_interval_common &i2) const
bool operator!= (const Persistence_interval_common &i2) const
bool operator< (const Persistence_interval_common &i2) const
Detailed Description
template<typename Filtration_type, typename Coefficient_field>
class Gudhi::Persistence_interval_common< Filtration_type, Coefficient_field >
This is a class to store persistence intervals. Its main purpose is to exchange data in between different packages and provide unified way of writing a collection of persistence intervals to file.
Examples
rips_correlation_matrix_persistence.cpp.
Constructor & Destructor Documentation
◆ Persistence_interval_common() [1/3]
template<typename Filtration_type , typename Coefficient_field >
Gudhi::Persistence_interval_common< Filtration_type, Coefficient_field >::Persistence_interval_common ( Filtration_type  birth,
inline
Constructor taking as an input birth and death of the pair.
◆ Persistence_interval_common() [2/3]
unsigned  dim
inline
Constructor taking as an input birth, death and dimension of the pair.
◆ Persistence_interval_common() [3/3]
unsigned  dim,
inline
Constructor taking as an input birth, death, dimension of the pair as well as the number p such that this interval is present over Z_p field.
Member Function Documentation
◆ operator!=()
bool Gudhi::Persistence_interval_common< Filtration_type, Coefficient_field >::operator!= ( const Persistence_interval_common< Filtration_type, Coefficient_field > &  i2) const
inline
Check if two persistence paris are not equal.
◆ operator<()
bool Gudhi::Persistence_interval_common< Filtration_type, Coefficient_field >::operator< ( const Persistence_interval_common< Filtration_type, Coefficient_field > &  i2) const
inline
Operator to compare objects of a type Persistence_interval_common. One intervals is smaller than the other if it has lower persistence. Note that this operator do not take Arith_element into account when doing comparisons.
◆ operator==()
bool Gudhi::Persistence_interval_common< Filtration_type, Coefficient_field >::operator== ( const Persistence_interval_common< Filtration_type, Coefficient_field > &  i2) const
inline
Operator to compare two persistence pairs. During the comparison all the fields: birth, death, dimensiona and arith_element_ are taken into account and they all have to be equal for two pairs to be equal.
The documentation for this class was generated from the following file:
