Contains the Gudhi::persistence_fields::Multi_field_operators_with_small_characteristics class. More...
Go to the source code of this file.
Classes | |
| class | Gudhi::persistence_fields::Multi_field_operators_with_small_characteristics |
Class defining operators for a multi-field with "consecutive" characteristic range, such that productOfAllCharacteristics ^ 2 fits into an unsigned int. More... | |
Namespaces | |
| namespace | Gudhi |
| Gudhi namespace. | |
| namespace | Gudhi::persistence_fields |
| Field namespace. | |
