Base_matrix_with_column_compression.h File Reference
Contains the Gudhi::persistence_matrix::Base_matrix_with_column_compression class. More...
Go to the source code of this file.
Classes
class  Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >
 A base matrix (also see Base_matrix), but with column compression. That is, all identical columns in the matrix are compressed together as the same column. For matrices with a lot of redundant columns, this will save a lot of space. Also, any addition made onto a column will be performed at the same time on all other identical columns, which is an advantage for the cohomology algorithm for example. More...
class  Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::Column
 Type for columns. Only one for each "column class" is explicitly constructed. More...
Namespaces
namespace  Gudhi
 Gudhi namespace.
namespace  Gudhi::persistence_matrix
 Persistence matrix namespace.
Detailed Description
Author
Hannah Schreiber
