Gudhi::persistence_matrix::Representative_cycles_options< col_type > Struct Template Reference
Options needed to use the representative cycles. More...
Detailed Description
template<Column_types col_type = Column_types::INTRUSIVE_SET>
struct Gudhi::persistence_matrix::Representative_cycles_options< col_type >
Template Parameters
col_typeColumn type for the matrix.
The documentation for this struct was generated from the following file:
