Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::persistence_matrix::Dummy_base_pairing Struct Reference
Empty structure. Inheritated instead of Base_pairing, when the computation of the barcode was not enabled or if the pairing is already managed by the vine update classes. More...
Detailed Description
The documentation for this struct was generated from the following file:
