Gudhi::persistence_matrix::Cohomology_persistence_options< column_type, is_z2_only, FieldOperators > Struct Template Reference
Options used by the cohomology module. More...
Detailed Description
template<Column_types column_type = Column_types::INTRUSIVE_LIST, bool is_z2_only = true, class FieldOperators = persistence_fields::Zp_field_operators<>>
struct Gudhi::persistence_matrix::Cohomology_persistence_options< column_type, is_z2_only, FieldOperators >
Template Parameters
column_typeColumn type for the matrix.
is_z2_onlyTrue if Z2.
FieldOperatorsField operator.
The documentation for this struct was generated from the following file:
