Gudhi::coxeter_triangulation::Function_lemniscate_revolution_in_R3 Class Reference
A class that encodes the function, the zero-set of which is a surface of revolution around the x axis based on the lemniscate of Bernoulli embedded in R^3. More...
Public Member Functions
Eigen::VectorXd operator() (const Eigen::VectorXd &p) const
 Value of the function at a specified point. More...
std::size_t amb_d () const
 Returns the (ambient) domain dimension.
std::size_t cod_d () const
 Returns the codomain dimension.
Eigen::VectorXd seed () const
 Returns a point on the surface. This seed point is only one of two necessary seed points for the manifold tracing algorithm. See the method seed2() for the other point.
Eigen::VectorXd seed2 () const
 Returns a point on the surface. This seed point is only one of two necessary seed points for the manifold tracing algorithm. See the method seed() for the other point.
 Function_lemniscate_revolution_in_R3 (double a=1, Eigen::Vector3d off=Eigen::Vector3d::Zero())
 Constructor of the function that defines a surface of revolution around the x axis based on the lemniscate of Bernoulli embedded in R^3. More...
Detailed Description
Constructor & Destructor Documentation
◆ Function_lemniscate_revolution_in_R3()
Gudhi::coxeter_triangulation::Function_lemniscate_revolution_in_R3::Function_lemniscate_revolution_in_R3 ( double  a = 1,
Eigen::Vector3d  off = Eigen::Vector3d::Zero()
inline
Parameters
[in]aA numerical parameter.
[in]offOffset vector.
Member Function Documentation
◆ operator()()
Eigen::VectorXd Gudhi::coxeter_triangulation::Function_lemniscate_revolution_in_R3::operator() ( const Eigen::VectorXd &  p) const
inline
Parameters
[in]pThe input point. The dimension needs to coincide with the ambient dimension.
The documentation for this class was generated from the following file:
