Gudhi::coxeter_triangulation::Function_affine_plane_in_Rd Class Reference
A class for the function that defines an m-dimensional implicit affine plane embedded in d-dimensional Euclidean space. More...
Public Member Functions
Eigen::VectorXd operator() (const Eigen::VectorXd &p) const
 Value of the function at a specified point. More...
std::size_t amb_d () const
 Returns the domain dimension. Same as the ambient dimension of the sphere.
std::size_t cod_d () const
 Returns the codomain dimension. Same as the codimension of the sphere.
Eigen::VectorXd seed () const
 Returns a point on the affine plane.
 Function_affine_plane_in_Rd (const Eigen::MatrixXd &normal_matrix, const Eigen::VectorXd &offset)
 Constructor of the function that defines an m-dimensional implicit affine plane in the d-dimensional Euclidean space. More...
 Function_affine_plane_in_Rd (const Eigen::MatrixXd &normal_matrix)
 Constructor of the function that defines an m-dimensional implicit affine plane in the d-dimensional Euclidean space that passes through origin. More...
Detailed Description
Constructor & Destructor Documentation
◆ Function_affine_plane_in_Rd() [1/2]
Gudhi::coxeter_triangulation::Function_affine_plane_in_Rd::Function_affine_plane_in_Rd ( const Eigen::MatrixXd &  normal_matrix,
const Eigen::VectorXd &  offset
inline
Parameters
[in]normal_matrixA normal matrix of the affine plane. The number of rows should correspond to the ambient dimension, the number of columns should correspond to the size of the normal basis (codimension).
[in]offsetThe offset vector of the affine plane. The dimension of the vector should be the ambient dimension of the manifold.
◆ Function_affine_plane_in_Rd() [2/2]
Gudhi::coxeter_triangulation::Function_affine_plane_in_Rd::Function_affine_plane_in_Rd ( const Eigen::MatrixXd &  normal_matrix)
inline
Parameters
Member Function Documentation
◆ operator()()
Eigen::VectorXd Gudhi::coxeter_triangulation::Function_affine_plane_in_Rd::operator() ( const Eigen::VectorXd &  p) const
inline
Parameters
[in]pThe input point. The dimension needs to coincide with the ambient dimension.
The documentation for this class was generated from the following file:
