Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::alpha_complex::SimplicialComplexForAlpha Struct Reference
The concept SimplicialComplexForAlpha describes the requirements for a type to implement a simplicial complex, that can be created from a Alpha_complex. More...
Public Types
typedef unspecified Simplex_handle
typedef unspecified Vertex_handle
typedef unspecified Filtration_value
typedef unspecified Simplex_vertex_range
 Iterator over vertices of a simplex. More...
typedef unspecified Boundary_simplex_range
 Iterator over the boundaries of the complex, in an arbitrary order. More...
typedef unspecified Skeleton_simplex_range
 Iterator over the simplices of the skeleton of the complex, for a given dimension. More...
typedef unspecified Insertion_result_type
 Return type of an insertion of a simplex.
Public Member Functions
std::size_t num_vertices ()
int dimension (Simplex_handle simplex)
int assign_filtration (Simplex_handle simplex, Filtration_value filtration)
void insert_simplex_and_subfaces (std::vector< Vertex_handle > const &vertex_range, Filtration_value filtration)
 Inserts a simplex with vertices from a given simplex (represented by a vector of Vertex_handle) in the simplicial complex with the given 'filtration' value.
void make_filtration_non_decreasing ()
void prune_above_filtration (Filtration_value filtration)
Simplex_vertex_range simplex_vertex_range (Simplex_handle const &simplex)
 Returns a range over vertices of a given simplex.
Boundary_simplex_range boundary_simplex_range (Simplex_handle const &simplex)
 Returns a range over boundaries of a given simplex.
Public Attributes
Skeleton_simplex_range skeleton_simplex_range
 Returns a range over the simplices of the skeleton of the simplicial complex, for a given dimension.
Map interface
Conceptually a std::unordered_map<Simplex_handle,std::size_t>.
typedef unspecified Simplex_key
 Data stored for each simplex. More...
Simplex_key null_key ()
 Returns a constant dummy number that is either negative, or at least as large as the number of simplices. Suggested value: -1.
Simplex_key key (Simplex_handle sh)
 Returns the number stored for a simplex by assign_key(). More...
void assign_key (Simplex_handle sh, Simplex_key n)
 Store a number for a simplex, which can later be retrieved with key().
Detailed Description
Member Typedef Documentation
◆ Boundary_simplex_range
'value_type' must be 'Simplex_handle'.
◆ Filtration_value
Simplex filtration value type. Must be capable to represent the special value "Not-A-Number"
◆ Simplex_handle
Handle to specify a simplex.
◆ Simplex_key
Must be an integer type.
◆ Simplex_vertex_range
'value type' must be 'Vertex_handle'.
◆ Skeleton_simplex_range
◆ Vertex_handle
Handle to specify a vertex. Must be a non-negative integer.
Member Function Documentation
◆ assign_filtration()
int Gudhi::alpha_complex::SimplicialComplexForAlpha::assign_filtration ( Simplex_handle  simplex,
Assigns the 'simplex' with the given 'filtration' value.
◆ dimension()
int Gudhi::alpha_complex::SimplicialComplexForAlpha::dimension ( Simplex_handle  simplex)
Gets the 'simplex' dimension.
◆ key()
Simplex_key Gudhi::alpha_complex::SimplicialComplexForAlpha::key ( Simplex_handle  sh)
If assign_key() has not been called, it must return null_key().
◆ make_filtration_non_decreasing()
void Gudhi::alpha_complex::SimplicialComplexForAlpha::make_filtration_non_decreasing ( )
Browses the simplicial complex to make the filtration non-decreasing.
◆ num_vertices()
std::size_t Gudhi::alpha_complex::SimplicialComplexForAlpha::num_vertices ( )
Returns the number of vertices in the simplicial complex.
◆ prune_above_filtration()
void Gudhi::alpha_complex::SimplicialComplexForAlpha::prune_above_filtration ( Filtration_value  filtration)
Prune the simplicial complex above 'filtration' value given as parameter.
The documentation for this struct was generated from the following file:
