Gudhi::Hooks_simplex_base_link_nodes Struct Reference
Data structure to put all simplex tree nodes with same label into a list. More...
Detailed Description
Allows one to access all subtrees of the simplex tree rooted at a node with a given label. Used in particular for fast cofaces location, and fast insertion and deletion of edges in a flag complex.
Only if SimplexTreeOptions::link_nodes_by_label is true.
The documentation for this struct was generated from the following file:
