Gudhi::skeleton_blocker::Print_complex_visitor< Vertex_handle > Class Template Reference
A visitor that prints the visit information. More...
Public Member Functions
void on_changed_edge (Vertex_handle a, Vertex_handle b)
 Called when an edge changes, during the contraction of an edge.
void on_swaped_edge (Vertex_handle a, Vertex_handle b, Vertex_handle x)
 Called when performing an edge contraction when an edge bx is replaced by an edge ax (not already present). Precisely, this methods is called this way in contract_edge : add_edge_without_blockers(a,x) on_swaped_edge(a,b,x) remove_edge(b,x)
Detailed Description
template<typename Vertex_handle>
class Gudhi::skeleton_blocker::Print_complex_visitor< Vertex_handle >
The documentation for this class was generated from the following file:
