Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::persistence_matrix::Row_access< Master_matrix > Class Template Reference
Class managing the row access for the columns. More...
Public Types
using index = typename Master_matrix::index
using id_index = typename Master_matrix::id_index
using Cell_type = typename Master_matrix::Cell_type
using Row_container_type = typename Master_matrix::row_container_type
Public Member Functions
 Row_access ()
 Default constructor. Sets the column index to -1 and the row container to nullptr. Should only be used by dummy columns.
 Row_access (index columnIndex, Row_container_type *rows)
 Constructor setting the column index and the row container by the given values. More...
 Row_access (Row_access &&other) noexcept
 Move constructor. More...
void insert_cell (id_index rowIndex, Cell_type *cell)
 Inserts the given cell at the given row index. More...
void unlink (Cell_type *cell)
 Removes the given cell from its row. More...
void update_cell (const Cell_type &cell)
 If PersistenceMatrixOptions::has_intrusive_rows is false, updates the copy of the cell in its row. Otherwise does nothing. More...
index get_column_index () const
 Returns the MatIdx column index. More...
Friends
void swap (Row_access &r1, Row_access &r2)
 Swap operator.
Detailed Description
template<class Master_matrix>
class Gudhi::persistence_matrix::Row_access< Master_matrix >
Template Parameters
Master_matrixAn instanciation of Matrix from which all types and options are deduced.
Member Typedef Documentation
◆ Cell_type
template<class Master_matrix >
using Gudhi::persistence_matrix::Row_access< Master_matrix >::Cell_type = typename Master_matrix::Cell_type
Cell.
◆ id_index
using Gudhi::persistence_matrix::Row_access< Master_matrix >::id_index = typename Master_matrix::id_index
IDIdx index type.
◆ index
using Gudhi::persistence_matrix::Row_access< Master_matrix >::index = typename Master_matrix::index
MatIdx index type.
◆ Row_container_type
using Gudhi::persistence_matrix::Row_access< Master_matrix >::Row_container_type = typename Master_matrix::row_container_type
Type of the row container.
Constructor & Destructor Documentation
◆ Row_access() [1/2]
Gudhi::persistence_matrix::Row_access< Master_matrix >::Row_access ( index  columnIndex,
Row_container_type rows
inline
Parameters
columnIndexColumn index to store.
rowsPointer to the row container.
◆ Row_access() [2/2]
Gudhi::persistence_matrix::Row_access< Master_matrix >::Row_access ( Row_access< Master_matrix > &&  other)
inlinenoexcept
Move constructor.
Parameters
otherColumn to move.
Member Function Documentation
◆ get_column_index()
Row_access< Master_matrix >::index Gudhi::persistence_matrix::Row_access< Master_matrix >::get_column_index
inline
Returns
The MatIdx column index.
◆ insert_cell()
void Gudhi::persistence_matrix::Row_access< Master_matrix >::insert_cell ( id_index  rowIndex,
Cell_type cell
inline
Parameters
rowIndexRow index of the cell.
cellPointer to the cell to insert.
◆ unlink()
void Gudhi::persistence_matrix::Row_access< Master_matrix >::unlink ( Cell_type cell)
inline
Parameters
cellPointer to the cell to remove.
◆ update_cell()
void Gudhi::persistence_matrix::Row_access< Master_matrix >::update_cell ( const Cell_type cell)
inline
If the rows are intrusive, only a pointer of the cell is stored and therefore any update on the cell (value or column index) is automatically forwarded. But for non intrusive rows, any update has to be pushed explicitely.
Parameters
cellCell to update.
The documentation for this class was generated from the following file:
