Overlay for chain matrices replacing all input and output MatIdx indices of the original methods with PosIdx indices. The overlay is useless for boundary matrices as MatIdx == PosIdx for them. More...
Public Types | |
using | index = typename Master_matrix_type::index |
using | id_index = typename Master_matrix_type::id_index |
using | pos_index = typename Master_matrix_type::pos_index |
using | dimension_type = typename Master_matrix_type::dimension_type |
using | Field_operators = typename Master_matrix_type::Field_operators |
Field operators class. Necessary only if PersistenceMatrixOptions::is_z2 is false. | |
using | Field_element_type = typename Master_matrix_type::element_type |
using | boundary_type = typename Master_matrix_type::boundary_type |
using | Column_type = typename Master_matrix_type::Column_type |
using | Row_type = typename Master_matrix_type::Row_type |
using | bar_type = typename Master_matrix_type::Bar |
using | barcode_type = typename Master_matrix_type::barcode_type |
using | cycle_type = typename Master_matrix_type::cycle_type |
using | cell_rep_type = typename Master_matrix_type::cell_rep_type |
using | Cell_constructor = typename Master_matrix_type::Cell_constructor |
using | Column_settings = typename Master_matrix_type::Column_settings |
Public Member Functions | |
Position_to_index_overlay (Column_settings *colSettings) | |
Constructs an empty matrix. More... | |
template<class Boundary_type = boundary_type> | |
Position_to_index_overlay (const std::vector< Boundary_type > &orderedBoundaries, Column_settings *colSettings) | |
Constructs a new matrix from the given ranges of Matrix::cell_rep_type. Each range corresponds to a column (the order of the ranges are preserved). The content of the ranges is assumed to be sorted by increasing IDs. The IDs of the simplices are also assumed to be consecutifs, ordered by filtration value, starting with 0. More... | |
Position_to_index_overlay (unsigned int numberOfColumns, Column_settings *colSettings) | |
Constructs a new empty matrix and reserves space for the given number of columns. More... | |
template<typename BirthComparatorFunction , typename DeathComparatorFunction > | |
Position_to_index_overlay (Column_settings *colSettings, const BirthComparatorFunction &birthComparator, const DeathComparatorFunction &deathComparator) | |
Only available for chain matrices. Constructs an empty matrix and stores the given comparators. More... | |
template<typename BirthComparatorFunction , typename DeathComparatorFunction , class Boundary_type > | |
Position_to_index_overlay (const std::vector< Boundary_type > &orderedBoundaries, Column_settings *colSettings, const BirthComparatorFunction &birthComparator, const DeathComparatorFunction &deathComparator) | |
Only available for chain matrices. Constructs a new matrix from the given ranges of Matrix::cell_rep_type. Each range corresponds to a column (the order of the ranges are preserved). The content of the ranges is assumed to be sorted by increasing IDs. The IDs of the simplices are also assumed to be consecutifs, ordered by filtration value, starting with 0. More... | |
Position_to_index_overlay (unsigned int numberOfColumns, Column_settings *colSettings, const BirthComparatorFunction &birthComparator, const DeathComparatorFunction &deathComparator) | |
Only available for chain matrices. Constructs a new empty matrix and reserves space for the given number of columns. More... | |
Position_to_index_overlay (const Position_to_index_overlay &matrixToCopy, Column_settings *colSettings=nullptr) | |
Copy constructor. If colSettings is not a null pointer, its value is kept instead of the one in the copied matrix. More... | |
Position_to_index_overlay (Position_to_index_overlay &&other) noexcept | |
Move constructor. More... | |
void | insert_boundary (const Boundary_type &boundary, dimension_type dim=-1) |
Inserts at the end of the matrix a new ordered column corresponding to the given boundary. This means that it is assumed that this method is called on boundaries in the order of the filtration. It also assumes that the faces in the given boundary are identified by their relative position in the filtration, starting at 0. If it is not the case, use the other insert_boundary instead by indicating the face ID used in the boundaries when the face is inserted. More... | |
void | insert_boundary (id_index faceIndex, const Boundary_type &boundary, dimension_type dim=-1) |
It does the same as the other version, but allows the boundary faces to be identified without restrictions except that all IDs have to be strictly increasing in the order of filtration. Note that you should avoid then to use the other insertion method to avoid overwriting IDs. More... | |
Column_type & | get_column (pos_index position) |
Returns the column at the given PosIdx index. The type of the column depends on the choosen options, see PersistenceMatrixOptions::column_type. More... | |
const Column_type & | get_column (pos_index position) const |
Row_type & | get_row (id_index rowIndex) |
Only available if PersistenceMatrixOptions::has_row_access is true. Returns the row at the given row index. The type of the row depends on the choosen options, see PersistenceMatrixOptions::has_intrusive_rows. More... | |
const Row_type & | get_row (id_index rowIndex) const |
void | erase_empty_row (id_index rowIndex) |
Only available if PersistenceMatrixOptions::has_row_access and PersistenceMatrixOptions::has_removable_rows are true. Assumes that the row is empty and removes it. More... | |
void | remove_maximal_face (pos_index position) |
Only available if PersistenceMatrixOptions::has_removable_columns, PersistenceMatrixOptions::has_vine_update and PersistenceMatrixOptions::has_map_column_container are true. Assumes that the face is maximal in the current complex and removes it such that the matrix remains consistent (i.e., the matrix is still a compatible bases of the chain complex in the sense of [41]). The maximality of the face is not verified. Also updates the barcode if it was computed. More... | |
void | remove_last () |
Only available if PersistenceMatrixOptions::has_removable_columns is true and, if PersistenceMatrixOptions::has_map_column_container is true or PersistenceMatrixOptions::has_vine_update is false. Removes the last face in the filtration from the matrix and updates the barcode if it is stored. More... | |
dimension_type | get_max_dimension () const |
Returns the maximal dimension of a face stored in the matrix. Only available if PersistenceMatrixOptions::has_matrix_maximal_dimension_access is true. More... | |
index | get_number_of_columns () const |
Returns the current number of columns in the matrix. More... | |
dimension_type | get_column_dimension (pos_index position) const |
Returns the dimension of the given face. More... | |
void | add_to (pos_index sourcePosition, pos_index targetPosition) |
Adds column corresponding to sourcePosition onto the column corresponding to targetPosition . More... | |
void | multiply_target_and_add_to (pos_index sourcePosition, const Field_element_type &coefficient, pos_index targetPosition) |
Multiplies the target column with the coefficiant and then adds the source column to it. That is: targetColumn = (targetColumn * coefficient) + sourceColumn . More... | |
void | multiply_source_and_add_to (const Field_element_type &coefficient, pos_index sourcePosition, pos_index targetPosition) |
Multiplies the source column with the coefficiant before adding it to the target column. That is: targetColumn += (coefficient * sourceColumn) . The source column will not be modified. More... | |
bool | is_zero_cell (pos_index position, id_index rowIndex) const |
Indicates if the cell at given coordinates has value zero. More... | |
bool | is_zero_column (pos_index position) |
Indicates if the column at given index has value zero. More... | |
pos_index | get_column_with_pivot (id_index faceIndex) const |
Returns the PosIdx index of the column which has the given row index as pivot. Assumes that the pivot exists. More... | |
id_index | get_pivot (pos_index position) |
Returns the row index of the pivot of the given column. More... | |
void | reset (Column_settings *colSettings) |
Resets the matrix to an empty matrix. More... | |
Position_to_index_overlay & | operator= (const Position_to_index_overlay &other) |
Assign operator. | |
const barcode_type & | get_current_barcode () const |
Returns the current barcode of the matrix. Available only if PersistenceMatrixOptions::has_column_pairings is true. More... | |
void | update_representative_cycles () |
Only available if PersistenceMatrixOptions::can_retrieve_representative_cycles is true. Precomputes the representative cycles of the current state of the filtration represented by the matrix. It does not need to be called before get_representative_cycles is called for the first time, but needs to be called before calling get_representative_cycles again if the matrix was modified in between. Otherwise the old cycles will be returned. | |
const std::vector< cycle_type > & | get_representative_cycles () |
Only available if PersistenceMatrixOptions::can_retrieve_representative_cycles is true. Returns all representative cycles of the current filtration. More... | |
const cycle_type & | get_representative_cycle (const bar_type &bar) |
Only available if PersistenceMatrixOptions::can_retrieve_representative_cycles is true. Returns the cycle representing the given bar. More... | |
bool | vine_swap_with_z_eq_1_case (pos_index position) |
Only available if PersistenceMatrixOptions::has_vine_update is true. Does the same than vine_swap, but assumes that the swap is non trivial and therefore skips a part of the case study. More... | |
bool | vine_swap (pos_index position) |
Only available if PersistenceMatrixOptions::has_vine_update is true. Does a vine swap between two faces which are consecutives in the filtration. Roughly, if F is the current filtration represented by the matrix, the method modifies the matrix such that the new state corresponds to a valid state for the filtration F' equal to F but with the two faces at position position and position + 1 swapped. Of course, the two faces should not have a face/coface relation which each other ; F' has to be a valid filtration. See [21] for more information about vine and vineyards. More... | |
Friends | |
void | swap (Position_to_index_overlay &matrix1, Position_to_index_overlay &matrix2) |
Swap operator. | |
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::bar_type = typename Master_matrix_type::Bar |
Bar type.
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::barcode_type = typename Master_matrix_type::barcode_type |
Barcode type.
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::boundary_type = typename Master_matrix_type::boundary_type |
Type of an input column.
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::Cell_constructor = typename Master_matrix_type::Cell_constructor |
Factory of Cell classes.
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::cell_rep_type = typename Master_matrix_type::cell_rep_type |
Cell content representative.
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::Column_settings = typename Master_matrix_type::Column_settings |
Structure giving access to the columns to necessary external classes.
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::Column_type = typename Master_matrix_type::Column_type |
Column type.
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::cycle_type = typename Master_matrix_type::cycle_type |
Cycle type.
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::dimension_type = typename Master_matrix_type::dimension_type |
Dimension value type.
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::Field_element_type = typename Master_matrix_type::element_type |
Type of an field element.
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::id_index = typename Master_matrix_type::id_index |
IDIdx index type.
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::index = typename Master_matrix_type::index |
MatIdx index type.
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::pos_index = typename Master_matrix_type::pos_index |
PosIdx index type.
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::Row_type = typename Master_matrix_type::Row_type |
Row type, only necessary with row access option.
inline |
colSettings | Pointer to an existing setting structure for the columns. The structure should contain all the necessary external classes specifically necessary for the choosen column type, such as custom allocators. |
inline |
Boundary_type | Range type for Matrix::cell_rep_type ranges. Assumed to have a begin(), end() and size() method. |
orderedBoundaries | Range of boundaries: orderedBoundaries is interpreted as a boundary matrix of a filtered simplicial complex, whose boundaries are ordered by filtration order. Therefore, orderedBoundaries[i] should store the boundary of the i^{th} simplex in the filtration, as an ordered list of indices of its facets (again those indices correspond to their respective position in the matrix). That is why the indices of the simplices are assumed to be consecutifs and starting with 0 (an empty boundary is interpreted as a vertex boundary and not as a non existing simplex). All dimensions up to the maximal dimension of interest have to be present. If only a higher dimension is of interest and not everything should be stored, then use the insert_boundary method instead (after creating the matrix with the Position_to_index_overlay(unsigned int, Column_settings*) constructor preferably). |
inline |
numberOfColumns | Number of columns to reserve space for. |
inline |
BirthComparatorFunction | Type of the birth comparator: (pos_index, pos_index) -> bool |
DeathComparatorFunction | Type of the death comparator: (pos_index, pos_index) -> bool |
birthComparator | Method taking two PosIdx indices as input and returning true if and only if the birth associated to the first position is strictly less than birth associated to the second one with respect to some self defined order. It is used while swapping two unpaired or two negative columns. |
deathComparator | Method taking two PosIdx indices as input and returning true if and only if the death associated to the first position is strictly less than death associated to the second one with respect to some self defined order. It is used while swapping two positive but paired columns. |
inline |
orderedBoundaries | Range of boundaries: orderedBoundaries is interpreted as a boundary matrix of a filtered simplicial complex, whose boundaries are ordered by filtration order. Therefore, orderedBoundaries[i] should store the boundary of the i^{th} simplex in the filtration, as an ordered list of indices of its facets (again those indices correspond to their respective position in the matrix). That is why the indices of the simplices are assumed to be consecutifs and starting with 0 (an empty boundary is interpreted as a vertex boundary and not as a non existing simplex). All dimensions up to the maximal dimension of interest have to be present. If only a higher dimension is of interest and not everything should be stored, then use the insert_boundary method instead (after creating the matrix with the Position_to_index_overlay(unsigned int, Column_settings*, const BirthComparatorFunction&, const DeathComparatorFunction&) constructor preferably). |
inline |
inline |
matrixToCopy | Matrix to copy. |
colSettings | Either a pointer to an existing setting structure for the columns or a null pointer. The structure should contain all the necessary external classes specifically necessary for the choosen column type, such as custom allocators. If null pointer, the pointer stored in matrixToCopy is used instead. |
inlinenoexcept |
Move constructor.
other | Matrix to move. |
inline |
inline |
rowIndex | Row index of the empty row to remove. |
inline |
position | PosIdx index of the column to return. |
inline |
inline |
position | PosIdx index of the face. |
inline |
inline |
Recall that we assume that the boundaries were inserted in the order of filtration for the barcode to be valid.
inline |
inline |
inline |
inline |
bar | A bar from the current barcode. |
bar
inline |
inline |
rowIndex | Row index of the row to return. |
inline |
inline |
Different to the constructor, the boundaries do not have to come from a simplicial complex, but also from a more general cell complex. This includes cubical complexes or Morse complexes for example.
When inserted, the given boundary is reduced and from the reduction process, the column is deduced in the form of: IDIdx + linear combination of older column IDIdxs
. If the barcode is stored, it will be updated.
Boundary_type | Range of Matrix::cell_rep_type. Assumed to have a begin(), end() and size() method. |
boundary | Boundary generating the new column. The content should be ordered by ID. |
dim | Dimension of the face whose boundary is given. If the complex is simplicial, this parameter can be omitted as it can be deduced from the size of the boundary. |
inline |
As a face has to be inserted before one of its cofaces in a valid filtration (recall that it is assumed that the faces are inserted by order of filtration), it is sufficient to indicate the ID of the face being inserted.
faceID | IDIdx index to use to indentify the new face. |
boundary | Boundary generating the new column. The indices of the boundary have to correspond to the faceID values of precedent calls of the method for the corresponding faces and should be ordered in increasing order. |
inline |
inline |
Note that this method should always return false, as a valid chain matrix never has empty columns.
position | PosIdx index of the face corresponding to the column. |
inline |
inline |
inline |
See also remove_maximal_face.
inline |
See also remove_last.
position | PosIdx index of the face to remove. |
inline |
inline |
and position + 1
position | PosIdx index of the first face to swap. The second one has to be at position + 1 . |
inline |
