Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::persistence_matrix::Matrix_max_dimension_holder< dimension_type > Class Template Reference
Class managing the maximal dimension of a face represented in the inheritating matrix, when the option of face removal is not enabled. More...
Public Member Functions
 Matrix_max_dimension_holder (dimension_type maximalDimension=-1)
 Default constructor. If a dimension is specified, stores it as the maximal value. More...
 Matrix_max_dimension_holder (const Matrix_max_dimension_holder &toCopy)
 Copy constructor. More...
 Matrix_max_dimension_holder (Matrix_max_dimension_holder &&other) noexcept
 Move constructor. More...
dimension_type get_max_dimension () const
 Returns the maximal dimension of a face represented in the matrix. More...
Matrix_max_dimension_holderoperator= (const Matrix_max_dimension_holder &other)
 Assign operator.
Friends
void swap (Matrix_max_dimension_holder &matrix1, Matrix_max_dimension_holder &matrix2)
 Swap operator.
Detailed Description
template<typename dimension_type>
class Gudhi::persistence_matrix::Matrix_max_dimension_holder< dimension_type >
Template Parameters
dimension_typeDimension value type. Has to be an integer type. If unsigned, the maximal value of the type should not be attained during a run.
Constructor & Destructor Documentation
◆ Matrix_max_dimension_holder() [1/3]
template<typename dimension_type >
Gudhi::persistence_matrix::Matrix_max_dimension_holder< dimension_type >::Matrix_max_dimension_holder ( dimension_type  maximalDimension = -1)
inline
Parameters
maximalDimensionValue of the maximal dimension. Has to be either positive or -1. Default value: -1.
◆ Matrix_max_dimension_holder() [2/3]
Gudhi::persistence_matrix::Matrix_max_dimension_holder< dimension_type >::Matrix_max_dimension_holder ( const Matrix_max_dimension_holder< dimension_type > &  toCopy)
inline
Copy constructor.
Parameters
toCopyMatrix to copy.
◆ Matrix_max_dimension_holder() [3/3]
Gudhi::persistence_matrix::Matrix_max_dimension_holder< dimension_type >::Matrix_max_dimension_holder ( Matrix_max_dimension_holder< dimension_type > &&  other)
inlinenoexcept
Move constructor.
Parameters
otherMatrix to move.
Member Function Documentation
◆ get_max_dimension()
dimension_type Gudhi::persistence_matrix::Matrix_max_dimension_holder< dimension_type >::get_max_dimension ( ) const
inline
Returns
The maximal dimension.
The documentation for this class was generated from the following file:
