Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::persistence_matrix::Chain_representative_cycles< Master_matrix > Class Template Reference
Class managing the representative cycles for Chain_matrix if the option was enabled. More...
Public Types
using Bar = typename Master_matrix::Bar
using cycle_type = typename Master_matrix::cycle_type
using matrix_type = typename Master_matrix::column_container_type
Public Member Functions
 Chain_representative_cycles ()
 Default constructor.
 Chain_representative_cycles (const Chain_representative_cycles &matrixToCopy)
 Copy constructor. More...
 Chain_representative_cycles (Chain_representative_cycles &&other) noexcept
 Move constructor. More...
void update_representative_cycles ()
 Computes the current representative cycles of the matrix.
const std::vector< cycle_type > & get_representative_cycles ()
 Returns the current representative cycles. If the matrix is modified later after the first call, update_representative_cycles has to be called to update the returned cycles. More...
const cycle_typeget_representative_cycle (const Bar &bar)
 Returns the representative cycle corresponding to the given bar. If the matrix is modified later after the first call, update_representative_cycles has to be called to update the returned cycles. More...
Chain_representative_cyclesoperator= (Chain_representative_cycles other)
 Assign operator.
Friends
void swap (Chain_representative_cycles &base1, Chain_representative_cycles &base2)
 Swap operator.
Detailed Description
template<class Master_matrix>
class Gudhi::persistence_matrix::Chain_representative_cycles< Master_matrix >
Template Parameters
Master_matrixAn instanciation of Matrix from which all types and options are deduced.
Member Typedef Documentation
◆ Bar
template<class Master_matrix >
using Gudhi::persistence_matrix::Chain_representative_cycles< Master_matrix >::Bar = typename Master_matrix::Bar
Bar type.
◆ cycle_type
using Gudhi::persistence_matrix::Chain_representative_cycles< Master_matrix >::cycle_type = typename Master_matrix::cycle_type
Cycle type.
◆ matrix_type
using Gudhi::persistence_matrix::Chain_representative_cycles< Master_matrix >::matrix_type = typename Master_matrix::column_container_type
Column container type.
Constructor & Destructor Documentation
◆ Chain_representative_cycles() [1/2]
Gudhi::persistence_matrix::Chain_representative_cycles< Master_matrix >::Chain_representative_cycles ( const Chain_representative_cycles< Master_matrix > &  matrixToCopy)
inline
Copy constructor.
Parameters
matrixToCopyMatrix to copy.
◆ Chain_representative_cycles() [2/2]
Gudhi::persistence_matrix::Chain_representative_cycles< Master_matrix >::Chain_representative_cycles ( Chain_representative_cycles< Master_matrix > &&  other)
inlinenoexcept
Move constructor.
Parameters
otherMatrix to move.
Member Function Documentation
◆ get_representative_cycle()
const Chain_representative_cycles< Master_matrix >::cycle_type & Gudhi::persistence_matrix::Chain_representative_cycles< Master_matrix >::get_representative_cycle ( const Bar bar)
inline
Parameters
barBar corresponding to the wanted representative cycle.
Returns
A const reference to the representative cycle.
◆ get_representative_cycles()
const std::vector< typename Chain_representative_cycles< Master_matrix >::cycle_type > & Gudhi::persistence_matrix::Chain_representative_cycles< Master_matrix >::get_representative_cycles
inline
Returns
A const reference to a vector of Matrix::cycle_type containing all representative cycles.
The documentation for this class was generated from the following file:
