Loading [MathJax]/extensions/TeX/AMSmath.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::persistence_matrix::Chain_pairing< Master_matrix > Class Template Reference
Class managing the barcode for Chain_matrix if the option was enabled. More...
Public Types
using barcode_type = typename Master_matrix::barcode_type
using dimension_type = typename Master_matrix::dimension_type
Public Member Functions
 Chain_pairing ()
 Default constructor.
 Chain_pairing (const Chain_pairing &matrixToCopy)
 Copy constructor. More...
 Chain_pairing (Chain_pairing &&other) noexcept
 Move constructor. More...
const barcode_typeget_current_barcode () const
 Returns the current barcode which is maintained at any insertion, removal or vine swap. More...
Chain_pairingoperator= (Chain_pairing other)
 Assign operator.
Friends
void swap (Chain_pairing &pairing1, Chain_pairing &pairing2)
 Swap operator.
Detailed Description
template<class Master_matrix>
class Gudhi::persistence_matrix::Chain_pairing< Master_matrix >
Template Parameters
Master_matrixAn instanciation of Matrix from which all types and options are deduced.
Member Typedef Documentation
◆ barcode_type
template<class Master_matrix >
using Gudhi::persistence_matrix::Chain_pairing< Master_matrix >::barcode_type = typename Master_matrix::barcode_type
Barcode type.
◆ dimension_type
using Gudhi::persistence_matrix::Chain_pairing< Master_matrix >::dimension_type = typename Master_matrix::dimension_type
Dimension value type.
Constructor & Destructor Documentation
◆ Chain_pairing() [1/2]
Gudhi::persistence_matrix::Chain_pairing< Master_matrix >::Chain_pairing ( const Chain_pairing< Master_matrix > &  matrixToCopy)
inline
Copy constructor.
Parameters
matrixToCopyMatrix to copy.
◆ Chain_pairing() [2/2]
Gudhi::persistence_matrix::Chain_pairing< Master_matrix >::Chain_pairing ( Chain_pairing< Master_matrix > &&  other)
inlinenoexcept
Move constructor.
Parameters
otherMatrix to move.
Member Function Documentation
◆ get_current_barcode()
const Chain_pairing< Master_matrix >::barcode_type & Gudhi::persistence_matrix::Chain_pairing< Master_matrix >::get_current_barcode
inline
Returns
Const reference to the barcode.
The documentation for this class was generated from the following file:
