Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix > Class Template Reference
Class managing the pivot and partitioning of columns in Chain_matrix. More...
Public Types
using index = typename Master_matrix::index
using id_index = typename Master_matrix::id_index
Public Member Functions
 Chain_column_extra_properties ()
 Default constructor. Sets the pivot and pair to -1, which means "not existing".
 Chain_column_extra_properties (id_index pivot)
 Constructor setting the pivot at the given value and the pair to -1 (i.e. not paired). More...
 Chain_column_extra_properties (id_index pivot, index pair)
 Constructor setting the pivot and the pair at the given values. More...
 Chain_column_extra_properties (const Chain_column_extra_properties &col)
 Copy constructor. More...
 Chain_column_extra_properties (Chain_column_extra_properties &&col)
 Move constructor. More...
index get_paired_chain_index () const
 Returns -1 if the column is not paired, the MatIdx of the pair otherwise. More...
bool is_paired () const
 Indicates if the column is paired or not. More...
void assign_paired_chain (index other_col)
 Sets the value of the pair. More...
void unassign_paired_chain ()
 Unpairs a column.
Chain_column_extra_propertiesoperator= (const Chain_column_extra_properties &other)
 Assign operator.
Friends
void swap (Chain_column_extra_properties &col1, Chain_column_extra_properties &col2)
 Swap operator.
Detailed Description
template<class Master_matrix>
class Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix >
The columns of a chain matrix are partitioned in three sets: \( F \), \( G \) and \( H \) with a bijection between \( G \) and \( H \). If a column is in \( F \), the value of Chain_column_extra_properties::pairedColumn_ is -1, while the value corresponds to the MatIdx index of the image of the bijection if the column is in either \( G \) or \( H \). See [41] for more details.
Template Parameters
Master_matrixAn instanciation of Matrix from which all types and options are deduced.
Member Typedef Documentation
◆ id_index
template<class Master_matrix >
using Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix >::id_index = typename Master_matrix::id_index
IDIdx index type.
◆ index
using Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix >::index = typename Master_matrix::index
MatIdx index type.
Constructor & Destructor Documentation
◆ Chain_column_extra_properties() [1/4]
Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix >::Chain_column_extra_properties ( id_index  pivot)
inline
Parameters
pivotRow index of the pivot. Corresponds to the IDIdx index of the face represented by the column.
◆ Chain_column_extra_properties() [2/4]
Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix >::Chain_column_extra_properties ( id_index  pivot,
index  pair
inline
Parameters
pairMatIdx index of the pair of the column.
◆ Chain_column_extra_properties() [3/4]
Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix >::Chain_column_extra_properties ( const Chain_column_extra_properties< Master_matrix > &  col)
inline
Copy constructor.
Parameters
colColumn to copy.
◆ Chain_column_extra_properties() [4/4]
Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix >::Chain_column_extra_properties ( Chain_column_extra_properties< Master_matrix > &&  col)
inline
Move constructor.
Parameters
colColumn to move.
Member Function Documentation
◆ assign_paired_chain()
void Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix >::assign_paired_chain ( index  other_col)
inline
Parameters
other_colMatIdx of the pair column.
◆ get_paired_chain_index()
index Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix >::get_paired_chain_index ( ) const
inline
Returns
◆ is_paired()
bool Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix >::is_paired ( ) const
inline
Returns
true If the column is paired.
false Otherwise.
The documentation for this class was generated from the following file:
