The concept Topological_data_with_distances describes the requirements for a type to implement a container that allows computations of distance to another contained of that type. More...
The second parameter of the distance function allow to declare power of a distance. The exact meaning of that number will be different for different distances. A few examples are given below: In case of p-Wasserstein distance, the power is equal to p. power = std::limit<double>::max() for bottleneck distance.
In case of L^p landscape distance, the power is equal to p. s
