Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::coxeter_triangulation::Negation< Function_ > Class Template Reference
Constructs the "minus" function. The zero-set is the same, but the values at other points are the negative of their original value. More...
Public Member Functions
Eigen::VectorXd operator() (const Eigen::VectorXd &p) const
 Value of the function at a specified point. More...
std::size_t amb_d () const
 Returns the domain (ambient) dimension.
std::size_t cod_d () const
 Returns the codomain dimension.
Eigen::VectorXd seed () const
 Returns a point on the zero-set.
 Negation (const Function_ &function)
 Constructor of the negative function. More...
Detailed Description
template<class Function_>
class Gudhi::coxeter_triangulation::Negation< Function_ >
Template Parameters
Function_The function template parameter. Should be a model of the concept FunctionForImplicitManifold.
Constructor & Destructor Documentation
◆ Negation()
template<class Function_ >
Gudhi::coxeter_triangulation::Negation< Function_ >::Negation ( const Function_ &  function)
inline
Parameters
[in]functionThe function to be negated.
Member Function Documentation
◆ operator()()
Eigen::VectorXd Gudhi::coxeter_triangulation::Negation< Function_ >::operator() ( const Eigen::VectorXd &  p) const
inline
Parameters
[in]pThe input point. The dimension needs to coincide with the ambient dimension.
The documentation for this class was generated from the following file:
