Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::coxeter_triangulation::Mesh_medit Class Reference
Structure to store a mesh that can be output in Medit .mesh file format using the output_meshes_to_medit method. More...
Public Types
typedef std::vector< Eigen::VectorXd > Vertex_points
 Type of a range of vertices.
typedef std::pair< std::vector< std::size_t >, std::size_t > Mesh_element
 Type of a mesh element. A pair consisting of a vector of vertex indices of type std::size_t and of an integer that represents the common reference number for the mesh elements of this type.
typedef std::vector< Mesh_elementMesh_elements
 Type of a range of mesh elements.
typedef std::vector< double > Scalar_field_range
 Type of a range of scalar field .
Public Attributes
Vertex_points vertex_points
 Range of vertices of type Eigen::VectorXd to output.
Mesh_elements edges
 Range of edges.
Mesh_elements triangles
 Range of triangles.
Mesh_elements tetrahedra
 Range of tetrahedra.
Scalar_field_range triangles_scalar_range
 Range of scalar values over triangles.
Scalar_field_range tetrahedra_scalar_range
 Range of scalar values over tetrahedra.
Detailed Description
The documentation for this class was generated from the following file:
