A class that encodes the function, the zero-set of which is a surface of revolution around the x axis based on the lemniscate of Bernoulli embedded in R^3.
More...
Eigen::VectorXd | operator() (const Eigen::VectorXd &p) const |
| Value of the function at a specified point. More...
std::size_t | amb_d () const |
| Returns the (ambient) domain dimension.
std::size_t | cod_d () const |
| Returns the codomain dimension.
Eigen::VectorXd | seed () const |
| Returns a point on the surface. This seed point is only one of two necessary seed points for the manifold tracing algorithm. See the method seed2() for the other point.
Eigen::VectorXd | seed2 () const |
| Returns a point on the surface. This seed point is only one of two necessary seed points for the manifold tracing algorithm. See the method seed() for the other point.
| Function_lemniscate_revolution_in_R3 (double a=1, Eigen::Vector3d off=Eigen::Vector3d::Zero()) |
| Constructor of the function that defines a surface of revolution around the x axis based on the lemniscate of Bernoulli embedded in R^3. More...
◆ Function_lemniscate_revolution_in_R3()
Gudhi::coxeter_triangulation::Function_lemniscate_revolution_in_R3::Function_lemniscate_revolution_in_R3 |
double |
a = 1 , |
Eigen::Vector3d |
off = Eigen::Vector3d::Zero() |
inline |
- Parameters
[in] | a | A numerical parameter. |
[in] | off | Offset vector. |
◆ operator()()
Eigen::VectorXd Gudhi::coxeter_triangulation::Function_lemniscate_revolution_in_R3::operator() |
const Eigen::VectorXd & |
p | ) |
const |
inline |
- Parameters
[in] | p | The input point. The dimension needs to coincide with the ambient dimension. |
The documentation for this class was generated from the following file:
