A class that encodes a constant function from R^d to R^k. This class does not have any implicit manifold in correspondence.
More...
| Eigen::VectorXd | operator() (const Eigen::VectorXd &p) const |
| | Value of the function at a specified point. The value is constant. More...
std::size_t | amb_d () const |
| | Returns the domain dimension. Same as the ambient dimension of the sphere.
std::size_t | cod_d () const |
| | Returns the codomain dimension. Same as the codimension of the sphere.
Eigen::VectorXd | seed () const |
| | No seed point is available. Throws an exception on evocation.
| | Constant_function (std::size_t d, std::size_t k, const Eigen::VectorXd &value) |
| | Constructor of a constant function from R^d to R^m. More...
◆ Constant_function()
| Gudhi::coxeter_triangulation::Constant_function::Constant_function |
std::size_t |
d, |
std::size_t |
k, |
const Eigen::VectorXd & |
value |
inline |
- Parameters
| [in] | d | The domain dimension. |
| [in] | k | The codomain dimension. |
| [in] | value | The constant value of the function. |
◆ operator()()
| Eigen::VectorXd Gudhi::coxeter_triangulation::Constant_function::operator() |
p | ) |
const |
inline |
- Parameters
| [in] | p | The input point. The dimension needs to coincide with the ambient dimension. |
The documentation for this class was generated from the following file:
