Contains Gudhi::persistence_matrix::Matrix class. More...
Go to the source code of this file.
Classes | |
| class | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > |
| Data structure for matrices, and in particular thought for matrices representing filtered complexes in order to compute persistence and/or representative cycles. More... | |
| struct | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions >::Bar |
| Type for a bar in the computed barcode. Stores the birth, death and dimension of the bar. More... | |
| struct | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions >::RowCellComp |
| Compaires two cells by their position in the row. They are assume to be in the same row. More... | |
Namespaces | |
| Gudhi | |
| Gudhi namespace. | |
| Gudhi::persistence_matrix | |
| Persistence matrix namespace. | |
