Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::witness_complex::Euclidean_strong_witness_complex< Kernel_ > Class Template Reference
Constructs strong witness complex for given sets of witnesses and landmarks in Euclidean space. More...
Public Member Functions
template<typename LandmarkRange , typename WitnessRange >
 Euclidean_strong_witness_complex (const LandmarkRange &landmarks, const WitnessRange &witnesses)
 Initializes member variables before constructing simplicial complex. More...
template<typename Vertex_handle >
Point_d get_point (Vertex_handle vertex) const
 Returns the point corresponding to the given vertex.
- Public Member Functions inherited from Gudhi::witness_complex::Strong_witness_complex< std::vector< Gudhi::spatial_searching::Kd_tree_search< Kernel_, std::vector< Kernel_::Point_d > >::INS_range > >
 Strong_witness_complex (std::vector< Gudhi::spatial_searching::Kd_tree_search< Kernel_, std::vector< Kernel_::Point_d > >::INS_range > const &nearest_landmark_table)
bool create_complex (SimplicialComplexForWitness &complex, double max_alpha_square, Landmark_id limit_dimension=std::numeric_limits< Landmark_id >::max()) const
 Outputs the strong witness complex of relaxation 'max_alpha_square' in a simplicial complex data structure. More...
Detailed Description
template<class Kernel_>
class Gudhi::witness_complex::Euclidean_strong_witness_complex< Kernel_ >
Template Parameters
Kernel_requires a CGAL::Epick_d class.
Examples
example_nearest_landmark_table.cpp, example_strong_witness_complex_off.cpp, example_witness_complex_off.cpp, example_witness_complex_sphere.cpp, strong_witness_persistence.cpp, and weak_witness_persistence.cpp.
Constructor & Destructor Documentation
◆ Euclidean_strong_witness_complex()
template<class Kernel_ >
Gudhi::witness_complex::Euclidean_strong_witness_complex< Kernel_ >::Euclidean_strong_witness_complex ( const LandmarkRange &  landmarks,
const WitnessRange &  witnesses
inline
Records landmarks from the range 'landmarks' into a table internally, as well as witnesses from the range 'witnesses'. Both ranges should have value_type Kernel_::Point_d.
The documentation for this class was generated from the following file:
