Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::Off_reader Class Reference
OFF file reader top class visitor. More...
Public Member Functions
template<typename OffVisitor >
bool read (OffVisitor &off_visitor)
 Read an OFF file and calls the following methods : More...
Detailed Description
OFF file must be conform to OFF file format
Member Function Documentation
◆ read()
bool Gudhi::Off_reader::read ( OffVisitor &  off_visitor)
inline
void init(int dim,int num_vertices,int num_faces,int num_edges); // from file header - num_edges may not be set
void point(const std::vector<double>& point); // for each point read
void maximal_face(const std::list<int>& face); // for each face read
void done(); // upon file read is finished
of the visitor when reading a point or a maximal face. Edges are not taken into account.
The documentation for this class was generated from the following file:
