Interface for a visitor of the edge contraction process. More...
Public Member Functions | |
| virtual void | on_started (ComplexType &complex) |
| Called before the edge contraction process starts. | |
| virtual void | on_stop_condition_reached () |
| Called when the algorithm stops. | |
| virtual void | on_collected (const Profile &profile, boost::optional< FT > cost) |
| Called during the collecting phase (when a cost is assigned to the edges), for each edge collected. | |
| virtual void | on_selected (const Profile &profile, boost::optional< FT > cost, int initial_count, int current_count) |
| Called during the processing phase (when edges are contracted), for each edge that is selected. | |
| virtual void | on_contracting (const Profile &profile, boost::optional< Point > placement) |
| Called when an edge is about to be contracted and replaced by a vertex whose position is *placement. | |
| virtual void | on_contracted (const Profile &profile, boost::optional< Point > placement) |
| Called when after an edge has been contracted onto a new point placement. A possibility would to remove popable blockers at this point for instance. | |
| virtual void | on_non_valid (const Profile &profile) |
| Called for each selected edge which cannot be contracted because the ValidContractionPredicate is false. | |
| GUDHI Version 3.1.1 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Fri Feb 7 2020 16:35:36 for GUDHI by Doxygen 1.8.13 |
