Loading [MathJax]/extensions/TeX/AMSmath.js
All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Skeleton_blocker_contractor.h
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): David Salinas
4  *
5  * Copyright (C) 2014 Inria
6  *
7  * Modification(s):
8  * - 2019/08 Vincent Rouvreau: Fix issue #10 for CGAL
9  * - YYYY/MM Author: Description of the modification
10  */
11
12 #ifndef SKELETON_BLOCKER_CONTRACTOR_H_
13 #define SKELETON_BLOCKER_CONTRACTOR_H_
14
15 #include <gudhi/Contraction/Edge_profile.h>
16 #include <gudhi/Contraction/policies/Cost_policy.h>
17 #include <gudhi/Contraction/policies/Edge_length_cost.h>
18 #include <gudhi/Contraction/policies/Placement_policy.h>
19 #include <gudhi/Contraction/policies/First_vertex_placement.h>
20 #include <gudhi/Contraction/policies/Valid_contraction_policy.h>
21 #include <gudhi/Contraction/policies/Dummy_valid_contraction.h> // xxx remove
22 #include <gudhi/Contraction/policies/Link_condition_valid_contraction.h> // xxx remove
23 #include <gudhi/Contraction/policies/Contraction_visitor.h>
24
25 #include <gudhi/Skeleton_blocker/Skeleton_blocker_complex_visitor.h>
26 #include <gudhi/Debug_utils.h>
27
28 // todo remove the queue to be independent from cgal
29 #include <CGAL/Modifiable_priority_queue.h>
30 #include <CGAL/version.h> // for CGAL_VERSION_NR
31
32 #include <boost/scoped_array.hpp>
33 #include <boost/scoped_ptr.hpp>
34
35 #include <memory>
36 #include <cassert>
37 #include <list>
38 #include <utility> // for pair
39 #include <vector>
40
41 // Make compilation fail - required for external projects - https://github.com/GUDHI/gudhi-devel/issues/10
42 #if CGAL_VERSION_NR < 1041101000
43 # error Skeleton_blocker_contractor is only available for CGAL >= 4.11
44 #endif
45
46 namespace Gudhi {
47
48 namespace contraction {
49
50 template <class Profile>
51 Placement_policy<Profile>* make_first_vertex_placement() {
52  return new First_vertex_placement<Profile>();
53 }
54
55 template <class Profile>
56 Valid_contraction_policy<Profile>* make_link_valid_contraction() {
57  return new Link_condition_valid_contraction<Profile>();
58 }
59
63 template <class Profile>
65  public:
66  typedef typename Profile::Point Point;
67  typedef typename Profile::Complex Complex;
68  typedef typename Complex::Vertex_handle Vertex_handle;
69
70  void on_contracted(const Profile &profile, boost::optional< Point > placement) override {
71  profile.complex().remove_all_popable_blockers(profile.v0_handle());
72  }
73 };
74
75 template <class Profile>
76 Contraction_visitor<Profile>* make_remove_popable_blockers_visitor() {
78 }
79
96 template<class GeometricSimplifiableComplex, class EdgeProfile = Edge_profile<GeometricSimplifiableComplex>>
98 typename GeometricSimplifiableComplex::Vertex_handle> {
99  GeometricSimplifiableComplex& complex_;
100
101  public:
102  typedef typename GeometricSimplifiableComplex::Graph_vertex Graph_vertex;
103  typedef typename GeometricSimplifiableComplex::Vertex_handle Vertex_handle;
104  typedef typename GeometricSimplifiableComplex::Simplex Simplex;
105  typedef typename GeometricSimplifiableComplex::Root_vertex_handle Root_vertex_handle;
106  typedef typename GeometricSimplifiableComplex::Graph_edge Graph_edge;
107  typedef typename GeometricSimplifiableComplex::Edge_handle Edge_handle;
108  typedef typename GeometricSimplifiableComplex::Point Point;
109
110  typedef EdgeProfile Profile;
111
112
117  typedef Edge_profile_factory<EdgeProfile> Edge_profile_factory_;
118
119
120
121  typedef boost::optional<double> Cost_type;
122  typedef boost::optional<Point> Placement_type;
123
124  typedef size_t size_type;
125
127
128  private:
129  struct Compare_id {
130  Compare_id() : algorithm_(0) { }
131
132  Compare_id(Self const* aAlgorithm) : algorithm_(aAlgorithm) { }
133
134  bool operator()(Edge_handle a, Edge_handle b) const {
135  return algorithm_->get_undirected_edge_id(a) < algorithm_->get_undirected_edge_id(b);
136  }
137
138  Self const* algorithm_;
139  };
140
141  struct Compare_cost {
142  Compare_cost() : algorithm_(0) { }
143
144  Compare_cost(Self const* aAlgorithm) : algorithm_(aAlgorithm) { }
145
146  bool operator()(Edge_handle a, Edge_handle b) const {
147  // NOTE: A cost is an optional<> value.
148  // Absent optionals are ordered first; that is, "none < T" and "T > none" for any defined T != none.
149  // In consequence, edges with undefined costs will be promoted to the top of the priority queue and popped out
150  // first.
151  return algorithm_->get_data(a).cost() < algorithm_->get_data(b).cost();
152  }
153
154  Self const* algorithm_;
155  };
156
157  struct Undirected_edge_id : boost::put_get_helper<size_type, Undirected_edge_id> {
158  typedef boost::readable_property_map_tag category;
159  typedef size_type value_type;
160  typedef size_type reference;
161  typedef Edge_handle key_type;
162
163  Undirected_edge_id() : algorithm_(0) { }
164
165  Undirected_edge_id(Self const* aAlgorithm) : algorithm_(aAlgorithm) { }
166
167  size_type operator[](Edge_handle e) const {
168  return algorithm_->get_undirected_edge_id(e);
169  }
170
171  Self const* algorithm_;
172  };
173
174  typedef CGAL::Modifiable_priority_queue<Edge_handle, Compare_cost, Undirected_edge_id> PQ;
175  typedef typename PQ::handle pq_handle;
176
177
178  // An Edge_data is associated with EVERY edge in the complex (collapsible or not).
179  // It relates the edge with the PQ-handle needed to update the priority queue
180  // It also relates the edge with a policy-based cache
181
182  class Edge_data {
183  public:
184  Edge_data() : PQHandle_(), cost_() { }
185
186  Cost_type const& cost() const {
187  return cost_;
188  }
189
190  Cost_type & cost() {
191  return cost_;
192  }
193
194  pq_handle PQ_handle() const {
195  return PQHandle_;
196  }
197
198  bool is_in_PQ() const {
199  return PQHandle_ != PQ::null_handle();
200  }
201
202  void set_PQ_handle(pq_handle h) {
203  PQHandle_ = h;
204  }
205
206  void reset_PQ_handle() {
207  PQHandle_ = PQ::null_handle();
208  }
209
210  private:
211  pq_handle PQHandle_;
212  Cost_type cost_;
213  };
214  typedef Edge_data* Edge_data_ptr;
215  typedef boost::scoped_array<Edge_data> Edge_data_array;
216
217  int get_undirected_edge_id(Edge_handle edge) const {
218  return complex_[edge].index();
219  }
220
221  const Edge_data& get_data(Edge_handle edge) const {
222  return edge_data_array_[get_undirected_edge_id(edge)];
223  }
224
225  Edge_data& get_data(Edge_handle edge) {
226  return edge_data_array_[get_undirected_edge_id(edge)];
227  }
228
229  Cost_type get_cost(const Profile & profile) const {
230  return (*cost_policy_)(profile, get_placement(profile));
231  }
232
233  Profile create_profile(Edge_handle edge) const {
234  if (edge_profile_factory_)
235  return edge_profile_factory_->make_profile(complex_, edge);
236  else
237  return Profile(complex_, edge);
238  }
239
240  void insert_in_PQ(Edge_handle edge, Edge_data& data) {
241  data.set_PQ_handle(heap_PQ_->push(edge));
242  ++current_num_edges_heap_;
243  }
244
245  void update_in_PQ(Edge_handle edge, Edge_data& data) {
246  data.set_PQ_handle(heap_PQ_->update(edge, data.PQ_handle()));
247  }
248
249  void remove_from_PQ(Edge_handle edge, Edge_data& data) {
250  data.set_PQ_handle(heap_PQ_->erase(edge, data.PQ_handle()));
251  --current_num_edges_heap_;
252  }
253
254  boost::optional<Edge_handle> pop_from_PQ() {
255  boost::optional<Edge_handle> edge = heap_PQ_->extract_top();
256  if (edge)
257  get_data(*edge).reset_PQ_handle();
258  return edge;
259  }
260
261  private:
269  void collect_edges() {
270  //
271  // Loop over all the edges in the complex in the heap
272  //
273  size_type size = complex_.num_edges();
274  DBG("Collecting edges ...");
275  DBGMSG("num edges :", size);
276
277  edge_data_array_.reset(new Edge_data[size]);
278
279  heap_PQ_.reset(new PQ(size, Compare_cost(this), Undirected_edge_id(this)));
280
281  std::size_t id = 0;
282
283  // xxx do a parralel for
284  for (auto edge : complex_.edge_range()) {
285  complex_[edge].index() = id++;
286  Profile const& profile = create_profile(edge);
287  Edge_data& data = get_data(edge);
288  data.cost() = get_cost(profile);
289  ++initial_num_edges_heap_;
290  insert_in_PQ(edge, data);
291  if (contraction_visitor_) contraction_visitor_->on_collected(profile, data.cost());
292  }
293
294  DBG("Edges collected.");
295  }
296
297  bool should_stop(double lCost, const Profile &profile) const {
298  return false;
299  }
300
301  boost::optional<Point> get_placement(const Profile& profile) const {
302  return (*placement_policy_)(profile);
303  }
304
305  bool is_contraction_valid(Profile const& profile, Placement_type placement) const {
306  if (!valid_contraction_policy_) return true;
307  return (*valid_contraction_policy_)(profile, placement);
308  }
309
310
311  public:
320  void contract_edges(int num_max_contractions = -1) {
321  DBG("\n\nContract edges");
322  int num_contraction = 0;
323
324  bool unspecified_num_contractions = (num_max_contractions == -1);
325  //
326  // Pops and processes each edge from the PQ
327  //
328  boost::optional<Edge_handle> edge;
329  while ((edge = pop_from_PQ()) && ((num_contraction < num_max_contractions) || (unspecified_num_contractions))) {
330  Profile const& profile = create_profile(*edge);
331  Cost_type cost(get_data(*edge).cost());
332  if (contraction_visitor_) contraction_visitor_->on_selected(profile, cost, 0, 0);
333
334  DBGMSG("\n\n---- Pop edge - num vertices :", complex_.num_vertices());
335
336  if (cost) {
337  DBGMSG("sqrt(cost):", std::sqrt(*cost));
338  if (should_stop(*cost, profile)) {
339  if (contraction_visitor_) contraction_visitor_->on_stop_condition_reached();
340  DBG("should_stop");
341  break;
342  }
343  Placement_type placement = get_placement(profile);
344  if (is_contraction_valid(profile, placement) && placement) {
345  DBG("contraction_valid");
346  contract_edge(profile, placement);
347  ++num_contraction;
348  } else {
349  DBG("contraction not valid");
350  if (contraction_visitor_) contraction_visitor_->on_non_valid(profile);
351  }
352  } else {
353  DBG("uncomputable cost");
354  }
355  }
356  if (contraction_visitor_) contraction_visitor_->on_stop_condition_reached();
357  }
358
359  bool is_in_heap(Edge_handle edge) const {
360  if (heap_PQ_->empty()) {
361  return false;
362  } else {
363  return edge_data_array_[get_undirected_edge_id(edge)].is_in_PQ();
364  }
365  }
366
367  bool is_heap_empty() const {
368  return heap_PQ_->empty();
369  }
370
376  boost::optional<std::pair<Edge_handle, Placement_type > > top_edge() {
377  boost::optional<std::pair<Edge_handle, Placement_type > > res;
378
379  if (!heap_PQ_->empty()) {
380  auto edge = heap_PQ_->top();
381  Profile const& profile = create_profile(edge);
382  Placement_type placement = get_placement(profile);
383  res = std::make_pair(edge, placement);
384  DBGMSG("top edge:", complex_[edge]);
385  }
386  return res;
387  }
388
395  Skeleton_blocker_contractor(GeometricSimplifiableComplex& complex)
396  : complex_(complex),
397  cost_policy_(new Edge_length_cost<Profile>),
398  placement_policy_(new First_vertex_placement<Profile>),
399  valid_contraction_policy_(new Link_condition_valid_contraction<Profile>),
400  contraction_visitor_(new Contraction_visitor_()),
401  edge_profile_factory_(0),
402  initial_num_edges_heap_(0),
403  current_num_edges_heap_(0) {
404  complex_.set_visitor(this);
405  if (contraction_visitor_) contraction_visitor_->on_started(complex);
406  collect_edges();
407  }
408
413  Skeleton_blocker_contractor(GeometricSimplifiableComplex& complex,
414  Cost_policy_ *cost_policy,
415  Placement_policy_ * placement_policy = new First_vertex_placement<Profile>,
416  Valid_contraction_policy_ * valid_contraction_policy =
418  Contraction_visitor_* contraction_visitor = new Contraction_visitor_(),
419  Edge_profile_factory_* edge_profile_factory = NULL) :
420  complex_(complex),
421  cost_policy_(cost_policy),
422  placement_policy_(placement_policy),
423  valid_contraction_policy_(valid_contraction_policy),
424  contraction_visitor_(contraction_visitor),
425  edge_profile_factory_(edge_profile_factory),
426  initial_num_edges_heap_(0),
427  current_num_edges_heap_(0) {
428  complex_.set_visitor(this);
429  if (contraction_visitor) contraction_visitor->on_started(complex);
430  collect_edges();
431  }
432
434  complex_.set_visitor(0);
435  }
436
437  private:
438  void contract_edge(const Profile& profile, Placement_type placement) {
439  if (contraction_visitor_) contraction_visitor_->on_contracting(profile, placement);
440
441  assert(complex_.contains_vertex(profile.v0_handle()));
442  assert(complex_.contains_vertex(profile.v1_handle()));
443  assert(placement);
444
445  profile.complex().point(profile.v0_handle()) = *placement;
446
447  // remark : this is not necessary since v1 will be deactivated
448  // profile.complex().point(profile.v1_handle()) = *placement;
449
450  complex_.contract_edge(profile.v0_handle(), profile.v1_handle());
451
452  assert(complex_.contains_vertex(profile.v0_handle()));
453  assert(!complex_.contains_vertex(profile.v1_handle()));
454
455  update_changed_edges();
456
457  // the visitor could do something as complex_.remove_popable_blockers();
458  if (contraction_visitor_) contraction_visitor_->on_contracted(profile, placement);
459  }
460
461  private:
462  // every time the visitor's method on_changed_edge is called, it adds an
463  // edge to changed_edges_
464  std::vector< Edge_handle > changed_edges_;
465
470  inline void on_changed_edge(Vertex_handle a, Vertex_handle b) override {
471  boost::optional<Edge_handle> ab(complex_[std::make_pair(a, b)]);
472  assert(ab);
473  changed_edges_.push_back(*ab);
474  }
475
476  void update_changed_edges() {
477  // xxx do a parralel for
478  DBG("update edges");
479
480  // sequential loop
481  for (auto ab : changed_edges_) {
482  // 1-get the Edge_handle corresponding to ab
483  // 2-change the data in mEdgeArray[ab.id()]
484  // 3-update the heap
485  Edge_data& data = get_data(ab);
486  Profile const& profile = create_profile(ab);
487  data.cost() = get_cost(profile);
488  if (data.is_in_PQ()) {
489  update_in_PQ(ab, data);
490  } else {
491  insert_in_PQ(ab, data);
492  }
493  }
494  changed_edges_.clear();
495  }
496
497
498  private:
499  void on_remove_edge(Vertex_handle a, Vertex_handle b) override {
500  boost::optional<Edge_handle> ab((complex_[std::make_pair(a, b)]));
501  assert(ab);
502  Edge_data& lData = get_data(*ab);
503  if (lData.is_in_PQ()) {
504  remove_from_PQ(*ab, lData);
505  }
506  }
507
508  private:
514  void on_swaped_edge(Vertex_handle a, Vertex_handle b, Vertex_handle x) override {
515  boost::optional<Edge_handle> ax(complex_[std::make_pair(a, x)]);
516  boost::optional<Edge_handle> bx(complex_[std::make_pair(b, x)]);
517  assert(ax && bx);
518  complex_[*ax].index() = complex_[*bx].index();
519  }
520
521  private:
527  void on_delete_blocker(const Simplex * blocker) override {
528  // we go for all pairs xy that belongs to the blocker
529  // note that such pairs xy are necessarily edges of the complex
530  // by definition of a blocker
531
532  // todo uniqument utile pour la link condition
533  // laisser a l'utilisateur ? booleen update_heap_on_removed_blocker?
534  Simplex blocker_copy(*blocker);
535  for (auto x = blocker_copy.begin(); x != blocker_copy.end(); ++x) {
536  for (auto y = x; ++y != blocker_copy.end();) {
537  auto edge_descr(complex_[std::make_pair(*x, *y)]);
538  assert(edge_descr);
539  Edge_data& data = get_data(*edge_descr);
540  Profile const& profile = create_profile(*edge_descr);
541  data.cost() = get_cost(profile);
542
543  // If the edge is already in the heap
544  // its priority has not changed.
545  // If the edge is not present, we reinsert it
546  // remark : we could also reinsert the edge
547  // only if it is valid
548  if (!data.is_in_PQ()) {
549  insert_in_PQ(*edge_descr, data);
550  }
551  }
552  }
553  }
554
555
556  private:
557  std::shared_ptr<Cost_policy_> cost_policy_;
558  std::shared_ptr<Placement_policy_> placement_policy_;
559  std::shared_ptr<Valid_contraction_policy_> valid_contraction_policy_;
560  std::shared_ptr<Contraction_visitor_> contraction_visitor_;
561
562  // in case the user wants to do something special when the edge profile
563  // are created (for instance add some info)
564  std::shared_ptr<Edge_profile_factory_> edge_profile_factory_;
565  Edge_data_array edge_data_array_;
566
567  boost::scoped_ptr<PQ> heap_PQ_;
568  int initial_num_edges_heap_;
569  int current_num_edges_heap_;
570 };
571
572 } // namespace contraction
573
574 } // namespace Gudhi
575
576 #endif // SKELETON_BLOCKER_CONTRACTOR_H_
Skeleton_blocker_contractor(GeometricSimplifiableComplex &complex)
Constructor with default policies.
Definition: Skeleton_blocker_contractor.h:395
Places the contracted point onto the first point of the edge.
Definition: First_vertex_placement.h:24
void contract_edges(int num_max_contractions=-1)
Contract edges.
Definition: Skeleton_blocker_contractor.h:320
Definition: SimplicialComplexForAlpha.h:14
Skeleton_blocker_contractor(GeometricSimplifiableComplex &complex, Cost_policy_ *cost_policy, Placement_policy_ *placement_policy=new First_vertex_placement< Profile >, Valid_contraction_policy_ *valid_contraction_policy=new Link_condition_valid_contraction< Profile >, Contraction_visitor_ *contraction_visitor=new Contraction_visitor_(), Edge_profile_factory_ *edge_profile_factory=NULL)
Constructor with customed policies.
Definition: Skeleton_blocker_contractor.h:413
boost::optional< std::pair< Edge_handle, Placement_type > > top_edge()
Returns an Edge_handle and a Placement_type. This pair consists in the edge with the lowest cost in t...
Definition: Skeleton_blocker_contractor.h:376
Interface for a visitor of the edge contraction process.
Definition: Contraction_visitor.h:27
A dummy visitor of a simplicial complex that does nothing.
Definition: Skeleton_blocker_complex_visitor.h:64
Policy to specify the cost of contracting an edge.
Definition: Cost_policy.h:25
return a cost corresponding to the squared length of the edge
Definition: Edge_length_cost.h:24
Class that allows to contract iteratively edges of a simplicial complex.
Definition: Skeleton_blocker_contractor.h:97
Policy to specify if an edge contraction is valid or not.
Definition: Valid_contraction_policy.h:23
Visitor to remove popable blockers after an edge contraction.
Definition: Skeleton_blocker_contractor.h:64
Policy to specify where the merged point had to be placed after an edge contraction.
Definition: Placement_policy.h:25
GUDHI  Version 3.1.1  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Fri Feb 7 2020 16:35:36 for GUDHI by Doxygen 1.8.13
