Gudhi::skeleton_blocker::Skeleton_blocker_simple_geometric_traits< GeometryTrait > Struct Template Reference
Simple traits that is a model of SkeletonBlockerGeometricDS and can be passed as a template argument to Skeleton_blocker_geometric_complex. More...
Classes
class  Simple_geometric_vertex
 Vertex with a point attached. More...
Additional Inherited Members
- Public Types inherited from Gudhi::skeleton_blocker::SkeletonBlockerGeometricDS< GeometryTrait >
typedef GeometryTrait GT
typedef GeometryTrait::Point Point
- Public Types inherited from Gudhi::skeleton_blocker::SkeletonBlockerDS
typedef int boost_vertex_handle
 index that allows to find the vertex in the boost graph
Detailed Description
template<typename GeometryTrait>
struct Gudhi::skeleton_blocker::Skeleton_blocker_simple_geometric_traits< GeometryTrait >
Examples:
Contraction/Garland_heckbert.cpp, and Contraction/Rips_contraction.cpp.
The documentation for this struct was generated from the following file:
GUDHI  Version 3.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Mon Jan 20 2020 14:12:58 for GUDHI by Doxygen 1.8.13
