Gudhi::skeleton_blocker::Vertex_iterator< SkeletonBlockerComplex > Class Template Reference
Iterator on the vertices of a simplicial complex. More...
Public Member Functions
 Vertex_iterator (const SkeletonBlockerComplex *complex_, int end)
Detailed Description
template<typename SkeletonBlockerComplex>
class Gudhi::skeleton_blocker::Vertex_iterator< SkeletonBlockerComplex >
Remarks
The increment operator go to the next active vertex.
Incrementation increases Vertex_handle.
Constructor & Destructor Documentation
◆ Vertex_iterator()
template<typename SkeletonBlockerComplex >
Gudhi::skeleton_blocker::Vertex_iterator< SkeletonBlockerComplex >::Vertex_iterator ( const SkeletonBlockerComplex *  complex_,
int  end
inline
return an iterator to the end.
The documentation for this class was generated from the following file:
GUDHI  Version 3.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Mon Jan 20 2020 14:12:58 for GUDHI by Doxygen 1.8.13
