Gudhi::skeleton_blocker::Triangle_iterator< SkeletonBlockerComplex > Class Template Reference
Iterator over the triangles of the simplicial complex. More...
Public Member Functions
 Triangle_iterator (const SkeletonBlockerComplex *complex, bool is_end)
 ugly hack to get an iterator to the end More...
Detailed Description
template<typename SkeletonBlockerComplex>
class Gudhi::skeleton_blocker::Triangle_iterator< SkeletonBlockerComplex >
Remarks
Will be removed soon -> dont look
Constructor & Destructor Documentation
◆ Triangle_iterator()
Gudhi::skeleton_blocker::Triangle_iterator< SkeletonBlockerComplex >::Triangle_iterator ( const SkeletonBlockerComplex *  complex,
bool  is_end
inline
Remarks
assume that the complex is non-empty
The documentation for this class was generated from the following file:
GUDHI  Version 3.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Mon Jan 20 2020 14:12:58 for GUDHI by Doxygen 1.8.13
