Gudhi::skeleton_blocker::Skeleton_blocker_complex_visitor< Vertex_handle > Class Template Referenceabstract
Interface for a visitor of a simplicial complex. More...
Public Member Functions
virtual void on_changed_edge (Vertex_handle a, Vertex_handle b)=0
 Called when an edge changes, during the contraction of an edge.
virtual void on_swaped_edge (Vertex_handle a, Vertex_handle b, Vertex_handle x)=0
 Called when performing an edge contraction when an edge bx is replaced by an edge ax (not already present). Precisely, this methods is called this way in contract_edge : add_edge_without_blockers(a,x) on_swaped_edge(a,b,x) remove_edge(b,x)
Detailed Description
template<typename Vertex_handle>
class Gudhi::skeleton_blocker::Skeleton_blocker_complex_visitor< Vertex_handle >
The documentation for this class was generated from the following file:
GUDHI  Version 3.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Mon Jan 20 2020 14:12:58 for GUDHI by Doxygen 1.8.13
