Gudhi::skeleton_blocker::Simplex_around_vertex_iterator< SkeletonBlockerComplex, Link > Class Template Reference
Public Member Functions
 Simplex_around_vertex_iterator (const Complex *complex_, Vertex_handle v_, bool end)
Detailed Description
template<typename SkeletonBlockerComplex, typename Link>
class Gudhi::skeleton_blocker::Simplex_around_vertex_iterator< SkeletonBlockerComplex, Link >
Link may be Skeleton_blocker_link_complex<SkeletonBlockerComplex> to iterate over all simplices around a vertex OR Skeleton_blocker_superior_link_complex<SkeletonBlockerComplex> to iterate over all superior vertices around a vertex. The iteration is done by computing a trie with the link and doing a breadth-first traversal of the trie.
Constructor & Destructor Documentation
◆ Simplex_around_vertex_iterator()
template<typename SkeletonBlockerComplex , typename Link >
Gudhi::skeleton_blocker::Simplex_around_vertex_iterator< SkeletonBlockerComplex, Link >::Simplex_around_vertex_iterator ( const Complex *  complex_,
Vertex_handle  v_,
bool  end
inline
returns an iterator to the end
The documentation for this class was generated from the following file:
GUDHI  Version 3.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Mon Jan 20 2020 14:12:58 for GUDHI by Doxygen 1.8.13
