16 #include <tbb/parallel_for.h> 17 #include <tbb/mutex.h> 20 #include <gudhi/Debug_utils.h> 21 #include <gudhi/graph_simplicial_complex.h> 23 #include <gudhi/Simplex_tree.h> 24 #include <gudhi/Rips_complex.h> 25 #include <gudhi/Points_off_io.h> 27 #include <gudhi/Persistent_cohomology.h> 28 #include <gudhi/Bottleneck.h> 30 #include <boost/config.hpp> 31 #include <boost/graph/graph_traits.hpp> 32 #include <boost/graph/adjacency_list.hpp> 33 #include <boost/graph/connected_components.hpp> 34 #include <boost/graph/dijkstra_shortest_paths.hpp> 35 #include <boost/graph/subgraph.hpp> 36 #include <boost/graph/graph_utility.hpp> 38 #include <CGAL/version.h> 53 namespace cover_complex {
58 using Persistence_diagram = std::vector<std::pair<double, double> >;
59 using Graph = boost::subgraph<
60 boost::adjacency_list<boost::setS, boost::vecS, boost::undirectedS, boost::no_property,
61 boost::property<boost::edge_index_t, int, boost::property<boost::edge_weight_t, double> > > >;
62 using Vertex_t = boost::graph_traits<Graph>::vertex_descriptor;
63 using Index_map = boost::property_map<Graph, boost::vertex_index_t>::type;
64 using Weight_map = boost::property_map<Graph, boost::edge_weight_t>::type;
86 template <
typename Po
int>
92 std::vector<Point> point_cloud;
93 std::vector<std::vector<double> > distances;
98 std::vector<double> func;
99 std::vector<double> func_color;
100 bool functional_cover =
false;
102 Graph one_skeleton_OFF;
104 std::vector<Vertex_t> vertices;
106 std::vector<std::vector<int> > simplices;
107 std::vector<int> voronoi_subsamples;
109 Persistence_diagram PD;
110 std::vector<double> distribution;
112 std::vector<std::vector<int> >
114 std::map<int, std::vector<int> >
116 std::map<int, double> cover_std;
120 std::map<int, std::pair<int, double> >
123 int resolution_int = -1;
124 double resolution_double = -1;
126 double rate_constant = 10;
127 double rate_power = 0.001;
130 std::map<int, int> name2id, name2idinv;
132 std::string cover_name;
133 std::string point_cloud_name;
134 std::string color_name;
137 void remove_edges(Graph& G) {
138 boost::graph_traits<Graph>::edge_iterator ei, ei_end;
139 for (boost::tie(ei, ei_end) = boost::edges(G); ei != ei_end; ++ei) boost::remove_edge(*ei, G);
144 #ifndef GUDHI_CAN_USE_CXX11_THREAD_LOCAL 145 std::default_random_engine re;
146 #endif // GUDHI_CAN_USE_CXX11_THREAD_LOCAL 149 double GetUniform() {
152 #ifdef GUDHI_CAN_USE_CXX11_THREAD_LOCAL 153 thread_local std::default_random_engine re;
154 #endif // GUDHI_CAN_USE_CXX11_THREAD_LOCAL 155 std::uniform_real_distribution<double> Dist(0, 1);
160 void SampleWithoutReplacement(
int populationSize,
int sampleSize, std::vector<int>& samples) {
164 while (m < sampleSize) {
166 if ((populationSize - t) * u >= sampleSize - m) {
205 rate_constant = constant;
228 n = point_cloud.size(); data_dimension = point_cloud[0].size();
229 point_cloud_name =
"matrix"; cover.resize(n);
230 for(
int i = 0; i < n; i++){
231 boost::add_vertex(one_skeleton_OFF);
232 vertices.push_back(boost::add_vertex(one_skeleton));
234 this->point_cloud = point_cloud;
243 point_cloud_name = off_file_name;
244 std::ifstream input(off_file_name);
248 while (comment ==
249 std::getline(input, line);
250 if (!line.empty() && !all_of(line.begin(), line.end(), (int (*)(int))isspace))
251 comment = line[line.find_first_not_of(
253 if (strcmp((
char*)line.c_str(),
"nOFF") == 0) {
255 while (comment ==
256 std::getline(input, line);
257 if (!line.empty() && !all_of(line.begin(), line.end(), (int (*)(int))isspace))
258 comment = line[line.find_first_not_of(
260 std::stringstream stream(line);
261 stream >> data_dimension;
267 int numedges, numfaces, i, dim;
268 while (comment ==
269 std::getline(input, line);
270 if (!line.empty() && !all_of(line.begin(), line.end(), (int (*)(int))isspace))
271 comment = line[line.find_first_not_of(
273 std::stringstream stream(line);
280 std::getline(input, line);
281 if (!line.empty() && line[line.find_first_not_of(
282 !all_of(line.begin(), line.end(), (int (*)(int))isspace)) {
283 std::stringstream iss(line);
284 std::vector<double> point;
285 point.assign(std::istream_iterator<double>(iss), std::istream_iterator<double>());
286 point_cloud.emplace_back(point.begin(), point.begin() + data_dimension);
287 boost::add_vertex(one_skeleton_OFF);
288 vertices.push_back(boost::add_vertex(one_skeleton));
289 cover.emplace_back();
295 while (i < numfaces) {
296 std::getline(input, line);
297 if (!line.empty() && line[line.find_first_not_of(
298 !all_of(line.begin(), line.end(), (int (*)(int))isspace)) {
299 std::vector<int> simplex;
300 std::stringstream iss(line);
301 simplex.assign(std::istream_iterator<int>(iss), std::istream_iterator<int>());
303 for (
int j = 1; j <= dim; j++)
304 for (
int k = j + 1; k <= dim; k++)
305 boost::add_edge(vertices[simplex[j]], vertices[simplex[k]], one_skeleton_OFF);
310 return input.is_open();
326 remove_edges(one_skeleton);
328 std::ifstream input(graph_file_name);
331 while (std::getline(input, line)) {
332 std::stringstream stream(line);
334 while (stream >> neighb) boost::add_edge(vertices[source], vertices[neighb], one_skeleton);
343 remove_edges(one_skeleton);
344 if (num_edges(one_skeleton_OFF))
345 one_skeleton = one_skeleton_OFF;
347 std::cout <<
"No triangulation read in OFF file!" << std::endl;
357 template <
typename Distance>
359 remove_edges(one_skeleton);
360 if (distances.size() == 0) compute_pairwise_distances(distance);
361 for (
int i = 0; i < n; i++) {
362 for (
int j = i + 1; j < n; j++) {
363 if (distances[i][j] <= threshold) {
364 boost::add_edge(vertices[i], vertices[j], one_skeleton);
365 boost::put(boost::edge_weight, one_skeleton, boost::edge(vertices[i], vertices[j], one_skeleton).first,
373 void set_graph_weights() {
374 Index_map index = boost::get(boost::vertex_index, one_skeleton);
375 Weight_map weight = boost::get(boost::edge_weight, one_skeleton);
376 boost::graph_traits<Graph>::edge_iterator ei, ei_end;
377 for (boost::tie(ei, ei_end) = boost::edges(one_skeleton); ei != ei_end; ++ei)
378 boost::put(weight, *ei,
379 distances[index[boost::source(*ei, one_skeleton)]][index[boost::target(*ei, one_skeleton)]]);
389 n = distance_matrix.size(); data_dimension = 0; point_cloud_name =
"matrix";
390 cover.resize(n); point_cloud.resize(n);
391 for(
392 boost::add_vertex(one_skeleton_OFF);
393 vertices.push_back(boost::add_vertex(one_skeleton));
395 distances = distance_matrix;
401 template <
typename Distance>
402 void compute_pairwise_distances(Distance ref_distance) {
404 std::vector<double> zeros(n);
405 for (
int i = 0; i < n; i++) distances.push_back(zeros);
406 std::string distance = point_cloud_name +
"_dist";
407 std::ifstream input(distance, std::ios::out | std::ios::binary);
410 if (verbose) std::cout <<
"Reading distances..." << std::endl;
411 for (
412 for (
int j = i; j < n; j++) {
413 input.read((
char*)&d, 8);
420 if (verbose) std::cout <<
"Computing distances..." << std::endl;
422 std::ofstream output(distance, std::ios::out | std::ios::binary);
423 for (
424 int state = (int)floor(100 * (i * 1.0 + 1) / n) % 10;
425 if (state == 0 && verbose) std::cout <<
"\r" << state <<
"%" << std::flush;
426 for (
427 double dis = ref_distance(point_cloud[i], point_cloud[j]);
428 distances[i][j] = dis;
429 distances[j][i] = dis;
430 output.write((
char*)&dis, 8);
434 if (verbose) std::cout << std::endl;
448 template <
typename Distance>
450 int m = floor(n / std::exp((1 + rate_power) * std::log(std::log(n) / std::log(rate_constant))));
451 m = (std::min)(m, n - 1);
454 if (verbose) std::cout << n <<
" points in R^" << data_dimension << std::endl;
455 if (verbose) std::cout <<
"Subsampling " << m <<
" points" << std::endl;
457 if (distances.size() == 0) compute_pairwise_distances(distance);
461 #if defined(GUDHI_USE_TBB) && defined(GUDHI_CAN_USE_CXX11_THREAD_LOCAL) 462 tbb::mutex deltamutex;
463 tbb::parallel_for(0, N, [&](
int i){
464 std::vector<int> samples(m);
465 SampleWithoutReplacement(n, m, samples);
466 double hausdorff_dist = 0;
467 for (
int j = 0; j < n; j++) {
468 double mj = distances[j][samples[0]];
469 for (
int k = 1; k < m; k++) mj = (std::min)(mj, distances[j][samples[k]]);
470 hausdorff_dist = (std::max)(hausdorff_dist, mj);
473 delta += hausdorff_dist / N;
477 for (
int i = 0; i < N; i++) {
478 std::vector<int> samples(m);
479 SampleWithoutReplacement(n, m, samples);
480 double hausdorff_dist = 0;
481 for (
482 double mj = distances[j][samples[0]];
483 for (
484 hausdorff_dist = (std::max)(hausdorff_dist, mj);
486 delta += hausdorff_dist / N;
490 if (verbose) std::cout <<
"delta = " << delta << std::endl;
507 std::ifstream input(func_file_name);
510 while (std::getline(input, line)) {
511 std::stringstream stream(line);
516 functional_cover =
true;
517 cover_name = func_file_name;
527 if(point_cloud[0].size() > 0){
528 for (
int i = 0; i < n; i++) func.push_back(point_cloud[i][k]);
529 functional_cover =
true;
530 cover_name =
"coordinate " + std::to_string(k);
533 std::cout <<
"Only pairwise distances provided---cannot access " << k <<
"th coordinate; returning null vector instead" << std::endl;
534 for (
int i = 0; i < n; i++) func.push_back(0.0);
535 functional_cover =
true;
546 template <
class InputRange>
548 for (
function[i]);
549 functional_cover =
true;
565 if (!functional_cover) {
566 std::cout <<
"Cover needs to come from the preimages of a function." << std::endl;
569 if (type !=
"Nerve" && type !=
"GIC") {
570 std::cout <<
"Type of complex needs to be specified." << std::endl;
575 Index_map index = boost::get(boost::vertex_index, one_skeleton);
578 boost::graph_traits<Graph>::edge_iterator ei, ei_end;
579 for (boost::tie(ei, ei_end) = boost::edges(one_skeleton); ei != ei_end; ++ei)
580 reso = (std::max)(reso, std::abs(func[index[boost::source(*ei, one_skeleton)]] -
581 func[index[boost::target(*ei, one_skeleton)]]));
582 if (verbose) std::cout <<
"resolution = " << reso << std::endl;
583 resolution_double = reso;
586 if (type ==
"Nerve") {
587 boost::graph_traits<Graph>::edge_iterator ei, ei_end;
588 for (boost::tie(ei, ei_end) = boost::edges(one_skeleton); ei != ei_end; ++ei)
589 reso = (std::max)(reso, std::abs(func[index[boost::source(*ei, one_skeleton)]] -
590 func[index[boost::target(*ei, one_skeleton)]]) /
592 if (verbose) std::cout <<
593 resolution_double = reso;
624 if (resolution_double == -1 && resolution_int == -1) {
625 std::cout <<
"Number and/or length of intervals not specified" << std::endl;
629 std::cout <<
"Gain not specified" << std::endl;
634 double minf = (std::numeric_limits<float>::max)();
635 double maxf = std::numeric_limits<float>::lowest();
636 for (
637 minf = (std::min)(minf, func[i]);
638 maxf = (std::max)(maxf, func[i]);
640 if (verbose) std::cout <<
"Min function value = " << minf <<
" and Max function value = " << maxf << std::endl;
643 std::vector<std::pair<double, double> > intervals;
646 if (resolution_double == -1) {
647 double incr = (maxf - minf) / resolution_int;
649 double alpha = (incr * gain) / (2 - 2 * gain);
650 double y = minf + incr + alpha;
651 std::pair<double, double> interm(x, y);
652 intervals.push_back(interm);
653 for (
int i = 1; i < resolution_int - 1; i++) {
654 x = minf + i * incr - alpha;
655 y = minf + (i + 1) * incr + alpha;
656 std::pair<double, double> inter(x, y);
657 intervals.push_back(inter);
659 x = minf + (resolution_int - 1) * incr - alpha;
661 std::pair<double, double> interM(x, y);
662 intervals.push_back(interM);
663 res = intervals.size();
665 for (
int i = 0; i < res; i++)
666 std::cout <<
"Interval " << i <<
" = [" << intervals[i].first <<
", " << intervals[i].second <<
"]" 670 if (resolution_int == -1) {
672 double y = x + resolution_double;
673 while (y <= maxf && maxf - (y - gain * resolution_double) >= resolution_double) {
674 std::pair<double, double> inter(x, y);
675 intervals.push_back(inter);
676 x = y - gain * resolution_double;
677 y = x + resolution_double;
679 std::pair<double, double> interM(x, maxf);
680 intervals.push_back(interM);
681 res = intervals.size();
683 for (
684 std::cout <<
"Interval " << i <<
"]" 689 double y = x + resolution_double;
691 while (count < resolution_int && y <= maxf && maxf - (y - gain * resolution_double) >= resolution_double) {
692 std::pair<double, double> inter(x, y);
693 intervals.push_back(inter);
695 x = y - gain * resolution_double;
696 y = x + resolution_double;
698 res = intervals.size();
700 for (
701 std::cout <<
"Interval " << i <<
"]" 708 std::vector<int> points(n);
709 for (
int i = 0; i < n; i++) points[i] = i;
710 std::sort(points.begin(), points.end(), [
this](
int p1,
int p2){
return (this->func[p1] < this->func[p2]);});
714 Index_map index = boost::get(boost::vertex_index, one_skeleton);
715 std::map<int, std::vector<int> > preimages;
716 std::map<int, double> funcstd;
718 if (verbose) std::cout <<
"Computing preimages..." << std::endl;
719 for (
int i = 0; i < res; i++) {
721 std::pair<double, double> inter1 = intervals[i];
727 std::pair<double, double> inter3 = intervals[i - 1];
728 while (func[points[tmp]] < inter3.second && tmp != n) {
729 preimages[i].push_back(points[tmp]);
737 std::pair<double, double> inter2 = intervals[i + 1];
738 while (func[points[tmp]] < inter2.first && tmp != n) {
739 preimages[i].push_back(points[tmp]);
744 while (func[points[tmp]] < inter1.second && tmp != n) {
745 preimages[i].push_back(points[tmp]);
750 std::pair<double, double> inter3 = intervals[i - 1];
751 while (func[points[tmp]] < inter3.second && tmp != n) {
752 preimages[i].push_back(points[tmp]);
756 preimages[i].push_back(points[tmp]);
763 funcstd[i] = 0.5 * (u + v);
767 if (verbose) std::cout <<
"Computing connected components (parallelized)..." << std::endl;
768 tbb::mutex covermutex, idmutex;
769 tbb::parallel_for(0, res, [&](
int i){
771 Graph G = one_skeleton.create_subgraph();
772 int num = preimages[i].size();
773 std::vector<int> component(num);
774 for (
int j = 0; j < num; j++) boost::add_vertex(index[vertices[preimages[i][j]]], G);
775 boost::connected_components(G, &component[0]);
779 for (
int j = 0; j < num; j++) {
781 if (component[j] > max) max = component[j];
784 int identifier = ((i + component[j])*(i + component[j]) + 3 * i + component[j]) / 2;
788 cover[preimages[i][j]].push_back(identifier);
789 cover_back[identifier].push_back(preimages[i][j]);
790 cover_fct[identifier] = i;
791 cover_std[identifier] = funcstd[i];
792 cover_color[identifier].second += func_color[preimages[i][j]];
793 cover_color[identifier].first += 1;
803 if (verbose) std::cout <<
"Computing connected components..." << std::endl;
804 for (
806 Graph G = one_skeleton.create_subgraph();
807 int num = preimages[i].size();
808 std::vector<int> component(num);
809 for (
810 boost::connected_components(G, &component[0]);
814 for (
816 if (component[j] > max) max = component[j];
819 int identifier = (std::pow(i + component[j], 2) + 3 * i + component[j]) / 2;
822 cover[preimages[i][j]].push_back(identifier);
823 cover_back[identifier].push_back(preimages[i][j]);
824 cover_fct[identifier] = i;
825 cover_std[identifier] = funcstd[i];
826 cover_color[identifier].second += func_color[preimages[i][j]];
827 cover_color[identifier].first += 1;
835 maximal_dim =
id - 1;
836 for (std::map<
int, std::pair<int, double> >::iterator iit = cover_color.begin(); iit != cover_color.end(); iit++)
837 iit->second.second /= iit->second.first;
850 std::vector<int> cov_elts, cov_number;
851 std::ifstream input(cover_file_name);
853 while (std::getline(input, line)) {
855 std::stringstream stream(line);
856 while (stream >> cov) {
857 cov_elts.push_back(cov);
858 cov_number.push_back(cov);
859 cover_fct[cov] = cov;
860 cover_color[cov].second += func_color[i];
861 cover_color[cov].first++;
862 cover_back[cov].push_back(i);
868 std::sort(cov_number.begin(), cov_number.end());
869 std::vector<int>::iterator it = std::unique(cov_number.begin(), cov_number.end());
870 cov_number.resize(std::distance(cov_number.begin(), it));
872 maximal_dim = cov_number.size() - 1;
873 for (
int i = 0; i <= maximal_dim; i++) cover_color[i].second /= cover_color[i].first;
874 cover_name = cover_file_name;
884 template <
typename Distance>
886 voronoi_subsamples.resize(m);
887 SampleWithoutReplacement(n, m, voronoi_subsamples);
888 if (distances.size() == 0) compute_pairwise_distances(distance);
890 Weight_map weight = boost::get(boost::edge_weight, one_skeleton);
891 Index_map index = boost::get(boost::vertex_index, one_skeleton);
892 std::vector<double> mindist(n);
893 for (
int j = 0; j < n; j++) mindist[j] = (std::numeric_limits<double>::max)();
897 if (verbose) std::cout <<
"Computing geodesic distances (parallelized)..." << std::endl;
898 tbb::mutex coverMutex; tbb::mutex mindistMutex;
899 tbb::parallel_for(0, m, [&](
int i){
900 int seed = voronoi_subsamples[i];
901 std::vector<double> dmap(n);
902 boost::dijkstra_shortest_paths(
903 one_skeleton, vertices[seed],
904 boost::weight_map(weight).distance_map(boost::make_iterator_property_map(dmap.begin(), index)));
906 coverMutex.lock(); mindistMutex.lock();
907 for (
908 if (mindist[j] > dmap[j]) {
909 mindist[j] = dmap[j];
910 if (cover[j].size() == 0)
911 cover[j].push_back(i);
915 coverMutex.unlock(); mindistMutex.unlock();
918 for (
int i = 0; i < m; i++) {
919 if (verbose) std::cout <<
"Computing geodesic distances to seed " << i <<
"..." << std::endl;
920 int seed = voronoi_subsamples[i];
921 std::vector<double> dmap(n);
922 boost::dijkstra_shortest_paths(
923 one_skeleton, vertices[seed],
924 boost::weight_map(weight).distance_map(boost::make_iterator_property_map(dmap.begin(), index)));
926 for (
927 if (mindist[j] > dmap[j]) {
928 mindist[j] = dmap[j];
929 if (cover[j].size() == 0)
930 cover[j].push_back(i);
937 for (
938 cover_back[cover[i][0]].push_back(i);
939 cover_color[cover[i][0]].second += func_color[i];
940 cover_color[cover[i][0]].first++;
942 for (
int i = 0; i < m; i++) cover_color[i].second /= cover_color[i].first;
944 cover_name =
"Voronoi";
954 const std::vector<int>&
subpopulation(
int c) {
return cover_back[name2idinv[c]]; }
969 std::ifstream input(color_file_name);
972 while (std::getline(input, line)) {
973 std::stringstream stream(line);
975 func_color.push_back(f);
978 color_name = color_file_name;
988 if(point_cloud[0].size() > 0){
989 for (
int i = 0; i < n; i++) func_color.push_back(point_cloud[i][k]);
990 color_name =
"coordinate ";
991 color_name.append(std::to_string(k));
994 std::cout <<
995 for (
996 functional_cover =
true;
1008 for (
unsigned int i = 0; i < color.size(); i++) func_color.push_back(color[i]);
1017 std::string mapp = point_cloud_name +
"_sc.dot";
1018 std::ofstream graphic(mapp);
1020 double maxv = std::numeric_limits<double>::lowest();
1021 double minv = (std::numeric_limits<double>::max)();
1022 for (std::map<
int, std::pair<int, double> >::iterator iit = cover_color.begin(); iit != cover_color.end(); iit++) {
1023 maxv = (std::max)(maxv, iit->second.second);
1024 minv = (std::min)(minv, iit->second.second);
1028 std::vector<int> nodes;
1031 graphic <<
"graph GIC {" << std::endl;
1033 for (std::map<
1034 if (iit->second.first > mask) {
1035 nodes.push_back(iit->first);
1036 name2id[iit->first] = id;
1037 name2idinv[id] = iit->first;
1039 graphic << name2id[iit->first] <<
"[shape=circle fontcolor=black color=black label=\"" << name2id[iit->first]
1040 <<
":" << iit->second.first <<
"\" style=filled fillcolor=\"" 1041 << (1 - (maxv - iit->second.second) / (maxv - minv)) * 0.6 <<
", 1, 1\"]" << std::endl;
1046 int num_simplices = simplices.size();
1047 for (
int i = 0; i < num_simplices; i++)
1048 if (simplices[i].size() == 2) {
1049 if (cover_color[simplices[i][0]].first > mask && cover_color[simplices[i][1]].first > mask) {
1050 graphic <<
" " << name2id[simplices[i][0]] <<
" -- " << name2id[simplices[i][1]] <<
" [weight=15];" 1057 std::cout << mapp <<
" file generated. It can be visualized with e.g. neato." << std::endl;
1065 int num_simplices = simplices.size();
1067 std::string mapp = point_cloud_name +
"_sc.txt";
1068 std::ofstream graphic(mapp);
1070 for (
1071 if (simplices[i].size() == 2)
1072 if (cover_color[simplices[i][0]].first > mask && cover_color[simplices[i][1]].first > mask) num_edges++;
1074 graphic << point_cloud_name << std::endl;
1075 graphic << cover_name << std::endl;
1076 graphic << color_name << std::endl;
1077 graphic << resolution_double <<
" " << gain << std::endl;
1078 graphic << cover_color.size() <<
" " << num_edges << std::endl;
1081 for (std::map<
1082 graphic <<
id <<
" " << iit->second.second <<
" " << iit->second.first << std::endl;
1083 name2id[iit->first] = id;
1084 name2idinv[id] = iit->first;
1088 for (
1089 if (simplices[i].size() == 2)
1090 if (cover_color[simplices[i][0]].first > mask && cover_color[simplices[i][1]].first > mask)
1091 graphic << name2id[simplices[i][0]] <<
" " << name2id[simplices[i][1]] << std::endl;
1094 <<
" generated. It can be visualized with e.g. python KeplerMapperVisuFromTxtFile.py and firefox." 1104 assert(cover_name ==
"Voronoi");
1106 int m = voronoi_subsamples.size();
1109 std::vector<std::vector<int> > edges, faces;
1110 int numsimplices = simplices.size();
1112 std::string mapp = point_cloud_name +
"_sc.off";
1113 std::ofstream graphic(mapp);
1115 graphic <<
"OFF" << std::endl;
1116 for (
int i = 0; i < numsimplices; i++) {
1117 if (simplices[i].size() == 2) {
1119 edges.push_back(simplices[i]);
1121 if (simplices[i].size() == 3) {
1123 faces.push_back(simplices[i]);
1126 graphic << m <<
" " << numedges + numfaces << std::endl;
1127 for (
1128 if (data_dimension <= 3) {
1129 for (
int j = 0; j < data_dimension; j++) graphic << point_cloud[voronoi_subsamples[i]][j] <<
1130 for (
int j = data_dimension; j < 3; j++) graphic << 0 <<
1131 graphic << std::endl;
1133 for (
int j = 0; j < 3; j++) graphic << point_cloud[voronoi_subsamples[i]][j] <<
1136 for (
int i = 0; i < numedges; i++) graphic << 2 <<
" " << edges[i][0] <<
" " << edges[i][1] << std::endl;
1137 for (
int i = 0; i < numfaces; i++)
1138 graphic << 3 <<
" " << faces[i][0] <<
" " << faces[i][1] <<
" " << faces[i][2] << std::endl;
1140 std::cout << mapp <<
" generated. It can be visualized with e.g. geomview." << std::endl;
1155 double maxf = std::numeric_limits<double>::lowest();
1156 double minf = (std::numeric_limits<double>::max)();
1157 for (std::map<int, double>::iterator it = cover_std.begin(); it != cover_std.end(); it++) {
1158 maxf = (std::max)(maxf, it->second);
1159 minf = (std::min)(minf, it->second);
1163 for (
auto const& simplex : simplices) {
1164 std::vector<int> splx = simplex;
1169 for (std::map<int, double>::iterator it = cover_std.begin(); it != cover_std.end(); it++) {
1170 int vertex = it->first;
float val = it->second;
1171 int vert[] = {vertex};
int edge[] = {vertex, -2};
1185 for (
int i = 0; i < max_dim; i++) {
1187 int num_bars = bars.size();
if(i == 0) num_bars -= 1;
1188 if(verbose) std::cout << num_bars <<
" interval(s) in dimension " << i <<
":" << std::endl;
1189 for (
int j = 0; j < num_bars; j++) {
1190 double birth = bars[j].first;
1191 double death = bars[j].second;
1192 if (i == 0 && std::isinf(death))
continue;
1194 birth = minf + (birth + 2) * (maxf - minf);
1196 birth = minf + (2 - birth) * (maxf - minf);
1198 death = minf + (death + 2) * (maxf - minf);
1200 death = minf + (2 - death) * (maxf - minf);
1201 PD.push_back(std::pair<double, double>(birth, death));
1202 if (verbose) std::cout <<
" [" << birth <<
", " << death <<
"]" << std::endl;
1215 unsigned int sz = distribution.size();
1217 std::cout <<
"Already done!" << std::endl;
1219 for (
unsigned int i = 0; i < N - sz; i++) {
1220 if (verbose) std::cout <<
"Computing " << i <<
"th bootstrap, bottleneck distance = ";
1222 Cover_complex Cboot; Cboot.n = this->n; Cboot.data_dimension = this->data_dimension; Cboot.type = this->type; Cboot.functional_cover =
true;
1224 std::vector<int> boot(this->n);
1225 for (
int j = 0; j < this->n; j++) {
1226 double u = GetUniform();
1227 int id = std::floor(u * (this->n)); boot[j] = id;
1228 Cboot.point_cloud.push_back(this->point_cloud[
id]); Cboot.cover.emplace_back(); Cboot.func.push_back(this->func[
id]);
1229 boost::add_vertex(Cboot.one_skeleton_OFF); Cboot.vertices.push_back(boost::add_vertex(Cboot.one_skeleton));
1233 for (
1234 std::vector<double> dist(n);
1235 for (
int k = 0; k < n; k++) dist[k] = distances[boot[j]][boot[k]];
1236 Cboot.distances.push_back(dist);
1246 if (verbose) std::cout << db << std::endl;
1247 distribution.push_back(db);
1250 std::sort(distribution.begin(), distribution.end());
1261 unsigned int N = distribution.size();
1262 double d = distribution[std::floor(alpha * N)];
1263 if (verbose) std::cout <<
"Distance corresponding to confidence " << alpha <<
" is " << d << std::endl;
1274 unsigned int N = distribution.size();
1276 for (
unsigned int i = 0; i < N; i++)
1277 if (distribution[i] >= d){ level = i * 1.0 / N;
break; }
1278 if (verbose) std::cout <<
"Confidence level of distance " << d <<
" is " << level << std::endl;
1288 double distancemin = (std::numeric_limits<double>::max)();
int N = PD.size();
1289 for (
int i = 0; i < N; i++) distancemin = (std::min)(distancemin, 0.5 * std::abs(PD[i].second - PD[i].first));
1291 if (verbose) std::cout <<
"p value = " << p_value << std::endl;
1305 template <
typename SimplicialComplex>
1307 unsigned int dimension = 0;
1308 for (
1309 int numvert = simplex.size();
1310 double filt = std::numeric_limits<double>::lowest();
1311 for (
int i = 0; i < numvert; i++) filt = (std::max)(cover_color[simplex[i]].second, filt);
1312 complex.insert_simplex_and_subfaces(simplex, filt);
1313 if (dimension < simplex.size() - 1) dimension = simplex.size() - 1;
1321 if (type !=
"Nerve" && type !=
"GIC") {
1322 std::cout <<
1326 if (type ==
"Nerve") {
1327 for(
int i = 0; i < n; i++) simplices.push_back(cover[i]);
1328 std::sort(simplices.begin(), simplices.end());
1329 std::vector<std::vector<int> >::iterator it = std::unique(simplices.begin(), simplices.end());
1330 simplices.resize(std::distance(simplices.begin(), it));
1333 if (type ==
"GIC") {
1334 Index_map index = boost::get(boost::vertex_index, one_skeleton);
1336 if (functional_cover) {
1341 throw std::invalid_argument(
1342 "the output of this function is correct ONLY if the cover is minimal, i.e. the gain is less than 0.5.");
1345 boost::graph_traits<Graph>::edge_iterator ei, ei_end;
1346 for (boost::tie(ei, ei_end) = boost::edges(one_skeleton); ei != ei_end; ++ei) {
1347 int nums = cover[index[boost::source(*ei, one_skeleton)]].size();
1348 for (
int i = 0; i < nums; i++) {
1349 int vs = cover[index[boost::source(*ei, one_skeleton)]][i];
1350 int numt = cover[index[boost::target(*ei, one_skeleton)]].size();
1351 for (
int j = 0; j < numt; j++) {
1352 int vt = cover[index[boost::target(*ei, one_skeleton)]][j];
1353 if (cover_fct[vs] == cover_fct[vt] + 1 || cover_fct[vt] == cover_fct[vs] + 1) {
1354 std::vector<int> edge(2);
1355 edge[0] = (std::min)(vs, vt);
1356 edge[1] = (std::max)(vs, vt);
1357 simplices.push_back(edge);
1364 std::sort(simplices.begin(), simplices.end());
1365 std::vector<std::vector<int> >::iterator it = std::unique(simplices.begin(), simplices.end());
1366 simplices.resize(std::distance(simplices.begin(), it));
1371 boost::graph_traits<Graph>::edge_iterator ei, ei_end;
1372 for (boost::tie(ei, ei_end) = boost::edges(one_skeleton); ei != ei_end; ++ei)
1373 if (!(cover[index[boost::target(*ei, one_skeleton)]].size() == 1 &&
1374 cover[index[boost::target(*ei, one_skeleton)]] == cover[index[boost::source(*ei, one_skeleton)]])) {
1375 std::vector<int> edge(2);
1376 edge[0] = index[boost::source(*ei, one_skeleton)];
1377 edge[1] = index[boost::target(*ei, one_skeleton)];
1390 std::vector<int> simplx;
1392 unsigned int sz = cover[vertex].size();
1393 for (
unsigned int i = 0; i < sz; i++) {
1394 simplx.push_back(cover[vertex][i]);
1397 std::sort(simplx.begin(), simplx.end());
1398 std::vector<int>::iterator it = std::unique(simplx.begin(), simplx.end());
1399 simplx.resize(std::distance(simplx.begin(), it));
1400 simplices.push_back(simplx);
1403 std::sort(simplices.begin(), simplices.end());
1404 std::vector<std::vector<int> >::iterator it = std::unique(simplices.begin(), simplices.end());
1405 simplices.resize(std::distance(simplices.begin(), it));
void init_coefficients(int charac)
Initializes the coefficient field.
Definition: Persistent_cohomology.h:156
void plot_DOT()
Creates a .dot file called SC.dot for neato (part of the graphviz package) once the simplicial comple...
Definition: GIC.h:1016
bool read_point_cloud(const std::string &off_file_name)
Reads and stores the input point cloud from .(n)OFF file.
Definition: GIC.h:242
void expansion(int max_dim)
Expands the Simplex_tree containing only its one skeleton until dimension max_dim.
Definition: Simplex_tree.h:1102
void set_mask(int nodemask)
Sets the mask, which is a threshold integer such that nodes in the complex that contain a number of d...
Definition: GIC.h:217
void set_function_from_range(InputRange const &function)
Creates the function f from a vector stored in memory.
Definition: GIC.h:547
void set_graph_from_file(const std::string &graph_file_name)
Creates a graph G from a file containing the edges.
Definition: GIC.h:325
Computes the persistent cohomology of a filtered complex.
Definition: Persistent_cohomology.h:52
const std::vector< int > & subpopulation(int c)
Returns the data subset corresponding to a specific node of the created complex.
Definition: GIC.h:954
Simplex Tree data structure for representing simplicial complexes.
Definition: Simplex_tree.h:60
std::pair< Simplex_handle, bool > insert_simplex_and_subfaces(const InputVertexRange &Nsimplex, Filtration_value filtration=0)
Insert a N-simplex and all his subfaces, from a N-simplex represented by a range of Vertex_handles...
Definition: Simplex_tree.h:750
double compute_distance_from_confidence_level(double alpha)
Computes the bottleneck distance threshold corresponding to a specific confidence level...
Definition: GIC.h:1260
void set_type(const std::string &t)
Specifies whether the type of the output simplicial complex.
Definition: GIC.h:186
void find_simplices()
Computes the simplices of the simplicial complex.
Definition: GIC.h:1320
void write_info()
Creates a .txt file called SC.txt describing the 1-skeleton, which can then be plotted with e...
Definition: GIC.h:1064
static Simplex_handle null_simplex()
Returns a Simplex_handle different from all Simplex_handles associated to the simplices in the simpli...
Definition: Simplex_tree.h:498
Compute the Euclidean distance between two Points given by a range of coordinates. The points are assumed to have the same dimension.
Definition: distance_functions.h:34
void set_function_from_coordinate(int k)
Creates the function f from the k-th coordinate of the point cloud P.
Definition: GIC.h:526
Persistence_diagram compute_PD()
Computes the extended persistence diagram of the complex.
Definition: GIC.h:1151
Definition: SimplicialComplexForAlpha.h:14
Rips complex data structure.
Definition: Rips_complex.h:45
void set_color_from_coordinate(int k=0)
Computes the function used to color the nodes of the simplicial complex from the k-th coordinate...
Definition: GIC.h:987
void create_complex(SimplicialComplex &complex)
Creates the simplicial complex.
Definition: GIC.h:1306
void set_graph_from_OFF()
Creates a graph G from the triangulation given by the input .OFF file.
Definition: GIC.h:342
void set_function_from_file(const std::string &func_file_name)
Creates the function f from a file containing the function values.
Definition: GIC.h:505
void set_subsampling(double constant, double power)
Sets the constants used to subsample the data set. These constants are explained in ...
Definition: GIC.h:204
void set_cover_from_Voronoi(Distance distance, int m=100)
Creates the cover C from the Voronoï cells of a subsampling of the point cloud.
Definition: GIC.h:885
void set_color_from_range(std::vector< double > color)
Computes the function used to color the nodes of the simplicial complex from a vector stored in memor...
Definition: GIC.h:1007
void set_verbose(bool verb=false)
Specifies whether the program should display information or not.
Definition: GIC.h:194
bool make_filtration_non_decreasing()
This function ensures that each simplex has a higher filtration value than its faces by increasing th...
Definition: Simplex_tree.h:1321
std::vector< std::pair< Filtration_value, Filtration_value > > intervals_in_dimension(int dimension)
Returns persistence intervals for a given dimension.
Definition: Persistent_cohomology.h:697
double compute_p_value()
Computes the p-value, i.e. the opposite of the confidence level of the largest bottleneck distance pr...
Definition: GIC.h:1287
Simplex_handle find(const InputVertexRange &s)
Given a range of Vertex_handles, returns the Simplex_handle of the simplex in the simplicial complex ...
Definition: Simplex_tree.h:584
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
Complex_simplex_range complex_simplex_range()
Returns a range over the simplices of the simplicial complex.
Definition: Simplex_tree.h:202
void assign_filtration(Simplex_handle sh, Filtration_value fv)
Sets the filtration value of a simplex.
Definition: Simplex_tree.h:488
Simplex_vertex_range simplex_vertex_range(Simplex_handle sh)
Returns a range over the vertices of a simplex.
Definition: Simplex_tree.h:249
void set_distances_from_range(const std::vector< std::vector< double > > &distance_matrix)
Reads and stores the distance matrices from vector stored in memory.
Definition: GIC.h:388
Global distance functions.
void set_graph_from_rips(double threshold, Distance distance)
Creates a graph G from a Rips complex.
Definition: GIC.h:358
bool has_children(SimplexHandle sh) const
Returns true if the node in the simplex tree pointed by sh has children.
Definition: Simplex_tree.h:571
void compute_distribution(unsigned int N=100)
Computes bootstrapped distances distribution.
Definition: GIC.h:1214
void plot_OFF()
Creates a .off file called SC.off for 3D visualization, which contains the 2-skeleton of the GIC...
Definition: GIC.h:1103
double bottleneck_distance(const Persistence_diagram1 &diag1, const Persistence_diagram2 &diag2, double e=(std::numeric_limits< double >::min)())
Function to compute the Bottleneck distance between two persistence diagrams.
Definition: Bottleneck.h:112
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:543
double set_graph_from_automatic_rips(Distance distance, int N=100)
Creates a graph G from a Rips complex whose threshold value is automatically tuned with subsampling—...
Definition: GIC.h:449
void set_color_from_file(const std::string &color_file_name)
Computes the function used to color the nodes of the simplicial complex from a file containing the fu...
Definition: GIC.h:967
double compute_confidence_level_from_distance(double d)
Computes the confidence level of a specific bottleneck distance threshold.
Definition: GIC.h:1273
void set_resolution_with_interval_number(int reso)
Sets a number of intervals from a value stored in memory.
Definition: GIC.h:611
void set_resolution_with_interval_length(double reso)
Sets a length of intervals from a value stored in memory.
Definition: GIC.h:605
void set_cover_from_file(const std::string &cover_file_name)
Creates the cover C from a file containing the cover elements of each point (the order has to be the ...
Definition: GIC.h:847
void set_cover_from_function()
Creates a cover C from the preimages of the function f.
Definition: GIC.h:623
Options::Filtration_value Filtration_value
Type for the value of the filtration function.
Definition: Simplex_tree.h:67
void compute_persistent_cohomology(Filtration_value min_interval_length=0)
Compute the persistent homology of the filtered simplicial complex.
Definition: Persistent_cohomology.h:172
Cover complex data structure.
Definition: GIC.h:87
double set_automatic_resolution()
Computes the optimal length of intervals (i.e. the smallest interval length avoiding discretization a...
Definition: GIC.h:564
This file includes common file reader for GUDHI.
void set_gain(double g=0.3)
Sets a gain from a value stored in memory (default value 0.3).
Definition: GIC.h:617
void set_point_cloud_from_range(const std::vector< std::vector< double > > &point_cloud)
Reads and stores the input point cloud from vector stored in memory.
Definition: GIC.h:227
