Gudhi::skeleton_blocker::SkeletonBlockerGeometricDS< GeometryTrait > Struct Template Reference
Concept for template class of Skeleton_blocker_geometric_complex . It must specify a GeometryTrait which contains a Point definition. More...
Classes
class  Graph_Edge
 Edge that allows to access to an index. The indices of the edges are used to store heap information in the edge contraction algorithm. More...
class  Graph_vertex
 Vertex that stores a point. More...
Public Types
typedef GeometryTrait GT
typedef GeometryTrait::Point Point
- Public Types inherited from Gudhi::skeleton_blocker::SkeletonBlockerDS
typedef int boost_vertex_handle
 index that allows to find the vertex in the boost graph
Detailed Description
template<typename GeometryTrait>
struct Gudhi::skeleton_blocker::SkeletonBlockerGeometricDS< GeometryTrait >
Graph_vertex must specify how to access to a point. Graph_edge must specify how to access to an index.
Member Typedef Documentation
◆ GT
template<typename GeometryTrait >
typedef GeometryTrait Gudhi::skeleton_blocker::SkeletonBlockerGeometricDS< GeometryTrait >::GT
Geometry information.
◆ Point
typedef GeometryTrait::Point Gudhi::skeleton_blocker::SkeletonBlockerGeometricDS< GeometryTrait >::Point
Type of point (should be the same as GT::Point).
The documentation for this struct was generated from the following file:
GUDHI  Version 3.0.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Sep 24 2019 09:57:51 for GUDHI by Doxygen 1.8.13
