Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType > Class Template Reference
Simplicial subcomplex of a complex represented by a skeleton/blockers pair. More...
Public Member Functions
Vertex_handle add_vertex (Root_vertex_handle global)
void add_edge_without_blockers (Root_vertex_handle v1_root, Root_vertex_handle v2_root)
void add_blocker (const Root_simplex_handle &blocker_root)
void make_restricted_complex (const ComplexType &parent_complex, const Simplex &simplex)
void clear ()
boost::optional< Vertex_handle > get_address (Root_vertex_handle global) const
std::vector< boost::optional< Vertex_handle > > get_addresses (const Root_simplex_handle &s) const
- Public Member Functions inherited from Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >
Link_complex link (Vertex_handle v) const
Link_complex link (Edge_handle edge) const
Link_complex link (const Simplex &simplex) const
boost::optional< Simplexget_simplex_address (const Root_simplex_handle &s) const
 Compute the local vertices of 's' in the current complex If one of them is not present in the complex then the return value is uninitialized.
Root_simplex_handle get_id (const Simplex &local_simplex) const
 returns a simplex with vertices which are the id of vertices of the argument.
virtual bool contains (const Simplex &s) const
 returns true iff the simplex s belongs to the simplicial complex.
int num_connected_components () const
 returns the number of connected components in the graph of the 1-skeleton.
bool is_cone () const
 Test if the complex is a cone. More...
Vertex_handle operator[] (Root_vertex_handle global) const
 Return a local Vertex_handle of a vertex given a global one. More...
Graph_vertexoperator[] (Vertex_handle address)
 Return the vertex node associated to local Vertex_handle. More...
const Graph_vertexoperator[] (Vertex_handle address) const
Vertex_handle add_vertex ()
 Adds a vertex to the simplicial complex and returns its Vertex_handle. More...
void remove_vertex (Vertex_handle address)
 Remove a vertex from the simplicial complex. More...
bool contains_vertex (Vertex_handle u) const
bool contains_vertex (Root_vertex_handle u) const
bool contains_vertices (const Simplex &sigma) const
virtual boost::optional< Vertex_handleget_address (Root_vertex_handle id) const
 Given an Id return the address of the vertex having this Id in the complex. More...
Root_vertex_handle get_id (Vertex_handle local) const
Vertex_handle convert_handle_from_another_complex (const Skeleton_blocker_complex &other, Vertex_handle vh_in_other) const
 Convert an address of a vertex of a complex to the address in the current complex. More...
int degree (Vertex_handle local) const
 return the graph degree of a vertex.
boost::optional< Edge_handleoperator[] (const std::pair< Vertex_handle, Vertex_handle > &ab) const
 return an edge handle if the two vertices forms an edge in the complex
Graph_edgeoperator[] (Edge_handle edge_handle)
 returns the stored node associated to an edge
const Graph_edgeoperator[] (Edge_handle edge_handle) const
Vertex_handle first_vertex (Edge_handle edge_handle) const
 returns the first vertex of an edge More...
Vertex_handle second_vertex (Edge_handle edge_handle) const
Simplex get_vertices (Edge_handle edge_handle) const
 returns the simplex made with the two vertices of the edge More...
Edge_handle add_edge (Vertex_handle a, Vertex_handle b)
 Adds an edge between vertices a and b. More...
void add_edge (const Simplex &s)
 Adds all edges of s in the complex.
Edge_handle add_edge_without_blockers (Vertex_handle a, Vertex_handle b)
 Adds an edge between vertices a and b without blockers. More...
void add_edge_without_blockers (Simplex s)
 Adds all edges of s in the complex without adding blockers.
virtual Edge_handle remove_edge (Vertex_handle a, Vertex_handle b)
 Removes an edge from the simplicial complex and all its cofaces. More...
void remove_edge (Edge_handle edge)
 Removes edge and its cofaces from the simplicial complex.
void keep_only_vertices ()
 The complex is reduced to its set of vertices. All the edges and blockers are removed.
bool contains_edge (Vertex_handle a, Vertex_handle b) const
bool contains_edges (const Simplex &sigma) const
std::string to_string () const
std::string vertices_to_string () const
std::string edges_to_string () const
std::string blockers_to_string () const
 Skeleton_blocker_complex (size_t num_vertices_=0, Visitor *visitor_=NULL)
 constructs a simplicial complex with a given number of vertices and a visitor.
template<typename SimpleHandleOutputIterator >
 Skeleton_blocker_complex (SimpleHandleOutputIterator simplices_begin, SimpleHandleOutputIterator simplices_end, bool is_flag_complex=false, Visitor *visitor_=NULL)
 Constructor with a list of simplices. More...
 Skeleton_blocker_complex (const Skeleton_blocker_complex &copy)
Skeleton_blocker_complexoperator= (const Skeleton_blocker_complex &copy)
bool operator== (const Skeleton_blocker_complex &other) const
bool operator!= (const Skeleton_blocker_complex &other) const
virtual ~Skeleton_blocker_complex ()
void set_visitor (Visitor *other_visitor)
 allows to change the visitor.
Blocker_handle add_blocker (const Simplex &blocker)
 Adds the simplex to the set of blockers and returns a Blocker_handle toward it if was not present before and 0 otherwise.
void remove_blocker (const Blocker_handle sigma)
 Removes the simplex from the set of blockers. More...
void remove_blockers ()
 Remove all blockers, in other words, it expand the simplicial complex to the smallest flag complex that contains it.
void delete_blocker (Blocker_handle sigma)
bool contains_blocker (const Blocker_handle s) const
bool contains_blocker (const Simplex &s) const
bool is_popable_blocker (Blocker_handle sigma) const
void remove_popable_blockers ()
void remove_popable_blockers (Vertex_handle v)
void remove_all_popable_blockers (Vertex_handle v)
 Removes all the popable blockers of the complex passing through v and delete them. Also remove popable blockers in the neighborhood if they became popable.
void remove_star (Vertex_handle v)
void remove_star (Vertex_handle a, Vertex_handle b)
void remove_star (Edge_handle e)
void remove_star (const Simplex &sigma)
void add_simplex (const Simplex &sigma)
 add a simplex and all its faces. More...
simplifiable_status is_remove_star_homotopy_preserving (const Simplex &simplex)
virtual contractible_status is_contractible () const
 Test if the complex is reducible using a strategy defined in the class (by default it tests if the complex is a cone) More...
bool link_condition (Vertex_handle a, Vertex_handle b, bool ignore_popable_blockers=false) const
bool link_condition (Edge_handle e, bool ignore_popable_blockers=false) const
void contract_edge (Edge_handle edge)
void contract_edge (Vertex_handle a, Vertex_handle b)
Complex_vertex_range vertex_range () const
 Returns a Complex_vertex_range over all vertices of the complex.
Complex_neighbors_vertices_range vertex_range (Vertex_handle v) const
 Returns a Complex_edge_range over all edges of the simplicial complex that passes trough v.
Complex_edge_range edge_range () const
 Returns a Complex_edge_range over all edges of the simplicial complex.
Complex_edge_around_vertex_range edge_range (Vertex_handle v) const
 Returns a Complex_edge_range over all edges of the simplicial complex that passes through 'v'.
Complex_triangle_around_vertex_range triangle_range (Vertex_handle v) const
 Range over triangles around a vertex of the simplicial complex. Methods .begin() and .end() return a Triangle_around_vertex_iterator.
Complex_triangle_range triangle_range () const
 Range over triangles of the simplicial complex. Methods .begin() and .end() return a Triangle_around_vertex_iterator.
Complex_simplex_around_vertex_range star_simplex_range (Vertex_handle v) const
 Returns a Complex_simplex_around_vertex_range over all the simplices around a vertex of the complex.
Complex_coboundary_range coboundary_range (const Simplex &s) const
 Returns a Complex_simplex_coboundary_iterator over the simplices of the coboundary of a simplex.
Complex_simplex_range complex_simplex_range () const
 Returns a Complex_simplex_range over all the simplices of the complex.
Complex_blocker_around_vertex_range blocker_range (Vertex_handle v)
 Returns a range of the blockers of the complex passing through a vertex.
Const_complex_blocker_around_vertex_range const_blocker_range (Vertex_handle v) const
Complex_blocker_range blocker_range ()
 Returns a range of the blockers of the complex.
Const_complex_blocker_range const_blocker_range () const
Additional Inherited Members
- Public Types inherited from Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >
typedef SkeletonBlockerDS::Graph_vertex Graph_vertex
 The type of stored vertex node, specified by the template SkeletonBlockerDS.
typedef SkeletonBlockerDS::Graph_edge Graph_edge
 The type of stored edge node, specified by the template SkeletonBlockerDS.
typedef SkeletonBlockerDS::Vertex_handle Vertex_handle
 The type of an handle to a vertex of the complex.
typedef Skeleton_blocker_simplex< Vertex_handleSimplex
 A ordered set of integers that represents a simplex.
typedef SimplexBlocker_handle
 Handle to a blocker of the complex.
typedef boost::graph_traits< Graph >::edge_descriptor Edge_handle
 Handle to an edge of the complex.
enum  simplifiable_status
enum  contractible_status
typedef Vertex_iterator< Skeleton_blocker_complexComplex_vertex_iterator
typedef boost::iterator_range< Complex_vertex_iteratorComplex_vertex_range
typedef Neighbors_vertices_iterator< Skeleton_blocker_complexComplex_neighbors_vertices_iterator
typedef boost::iterator_range< Complex_neighbors_vertices_iterator > Complex_neighbors_vertices_range
typedef Edge_iterator< Skeleton_blocker_complexComplex_edge_iterator
typedef boost::iterator_range< Complex_edge_iteratorComplex_edge_range
typedef Edge_around_vertex_iterator< Skeleton_blocker_complexComplex_edge_around_vertex_iterator
typedef boost::iterator_range< Complex_edge_around_vertex_iterator > Complex_edge_around_vertex_range
typedef Triangle_around_vertex_iterator< Skeleton_blocker_complex, Superior_linkSuperior_triangle_around_vertex_iterator
typedef boost::iterator_range< Triangle_around_vertex_iterator< Skeleton_blocker_complex, Link > > Complex_triangle_around_vertex_range
typedef boost::iterator_range< Triangle_iterator< Skeleton_blocker_complex > > Complex_triangle_range
typedef Triangle_iterator< Skeleton_blocker_complexComplex_triangle_iterator
typedef Simplex_around_vertex_iterator< Skeleton_blocker_complex, LinkComplex_simplex_around_vertex_iterator
typedef boost::iterator_range< Complex_simplex_around_vertex_iteratorComplex_simplex_around_vertex_range
 Range over the simplices of the simplicial complex around a vertex. Methods .begin() and .end() return a Complex_simplex_around_vertex_iterator.
typedef Simplex_coboundary_iterator< Skeleton_blocker_complex, LinkComplex_simplex_coboundary_iterator
typedef boost::iterator_range< Complex_simplex_coboundary_iteratorComplex_coboundary_range
 Range over the simplices of the coboundary of a simplex. Methods .begin() and .end() return a Complex_simplex_coboundary_iterator.
typedef Simplex_iterator< Skeleton_blocker_complexComplex_simplex_iterator
typedef boost::iterator_range< Complex_simplex_iterator > Complex_simplex_range
Detailed Description
template<typename ComplexType>
class Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType >
Stores a subcomplex of a simplicial complex. To simplify explanations below, we will suppose that :
  • K is the root simplicial complex
  • L is a subcomplex of K.
One vertex of K may exists in L but with a different address. To be able to locate the vertices in K from vertices of L, the class stores a map 'adresses' between vertices of K and vertices of L.
Note that the type for handle of vertices of L is 'Vertex_handle' and the type for handle of vertices of K is 'Root_vertex_handle'.
The template ComplexType is type of the root complex. It allows to know if the subcomplex is geometric or not. It has to be either 'Skeleton_blockers_complex' or 'Skeleton_blockers_geometric_complex'.
Member Function Documentation
◆ add_blocker()
template<typename ComplexType >
void Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType >::add_blocker ( const Root_simplex_handle &  blocker_root)
inline
Add a blocker to the sub-complex. It assumes that all vertices of blocker_root are present in the sub-complex.
◆ add_edge_without_blockers()
void Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType >::add_edge_without_blockers ( Root_vertex_handle  v1_root,
inline
Add an edge (v1_root,v2_root) to the sub-complex. It assumes that both vertices corresponding to v1_root and v2_root are present in the sub-complex.
◆ add_vertex()
Vertex_handle Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType >::add_vertex ( Root_vertex_handle  global)
inline
Add a vertex 'global' of K to L. When added to L, this vertex will receive another number, addresses(global), its local adress. return the adress where the vertex lay on L. The vertex corresponding to 'global' must not be already present in the complex.
◆ clear()
void Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType >::clear ( )
inlinevirtual
Clears the simplicial complex. After a call to this function, blockers are destroyed. The 1-skeleton and the set of blockers are both empty.
Reimplemented from Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS >.
◆ get_address()
boost::optional<Vertex_handle> Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType >::get_address ( Root_vertex_handle  global) const
inline
Compute the local vertex in L corresponding to the vertex global in K. runs in O(log n) if n = num_vertices()
◆ get_addresses()
std::vector<boost::optional<Vertex_handle> > Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType >::get_addresses ( const Root_simplex_handle &  s) const
inline
Allocates a simplex in L corresponding to the simplex s in K with its local adresses and returns an AddressSimplex. same as get_address except that it will return a simplex in any case. The vertices that were not found are not added.
◆ make_restricted_complex()
void Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType >::make_restricted_complex ( const ComplexType &  parent_complex,
const Simplex &  simplex
inline
Constructs the restricted complex of 'parent_complex' to vertices of 'simplex'.
The documentation for this class was generated from the following files:
GUDHI  Version 3.0.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Sep 24 2019 09:57:51 for GUDHI by Doxygen 1.8.13
