Cubical complex with periodic boundary conditions represented as a bitmap. More...
Public Member Functions | |
Bitmap_cubical_complex_periodic_boundary_conditions_base () | |
Bitmap_cubical_complex_periodic_boundary_conditions_base (const std::vector< unsigned > &sizes, const std::vector< bool > &directions_in_which_periodic_b_cond_are_to_be_imposed) | |
Bitmap_cubical_complex_periodic_boundary_conditions_base (const char *perseusStyleFile) | |
Bitmap_cubical_complex_periodic_boundary_conditions_base (const std::vector< unsigned > &dimensions, const std::vector< T > &topDimensionalCells, const std::vector< bool > &directions_in_which_periodic_b_cond_are_to_be_imposed) | |
virtual | ~Bitmap_cubical_complex_periodic_boundary_conditions_base () |
virtual std::vector< std::size_t > | get_boundary_of_a_cell (std::size_t cell) const |
virtual std::vector< std::size_t > | get_coboundary_of_a_cell (std::size_t cell) const |
virtual int | compute_incidence_between_cells (std::size_t coface, std::size_t face) |
Bitmap_cubical_complex_base () | |
Bitmap_cubical_complex_base (const std::vector< unsigned > &sizes) | |
Bitmap_cubical_complex_base (const char *perseus_style_file) | |
Bitmap_cubical_complex_base (const std::vector< unsigned > &dimensions, const std::vector< T > &top_dimensional_cells) | |
virtual | ~Bitmap_cubical_complex_base () |
virtual int | compute_incidence_between_cells (std::size_t coface, std::size_t face) const |
unsigned | get_dimension_of_a_cell (std::size_t cell) const |
T & | get_cell_data (std::size_t cell) |
void | impose_lower_star_filtration () |
unsigned | dimension () const |
unsigned | size () const |
void | put_data_to_bins (std::size_t number_of_bins) |
void | put_data_to_bins (T diameter_of_bin) |
std::pair< T, T > | min_max_filtration () |
All_cells_iterator | all_cells_iterator_begin () |
All_cells_iterator | all_cells_iterator_end () |
Boundary_range | boundary_range (std::size_t sh) |
Coboundary_range | coboundary_range (std::size_t sh) |
Top_dimensional_cells_iterator | top_dimensional_cells_iterator_begin () |
Top_dimensional_cells_iterator | top_dimensional_cells_iterator_end () |
Additional Inherited Members | |
typedef std::vector< std::size_t >::const_iterator | Boundary_iterator |
typedef std::vector< std::size_t >::const_iterator | Coboundary_iterator |
This is a class implementing a bitmap data structure with periodic boundary conditions. Most of the functions are identical to the functions from Bitmap_cubical_complex_base. The ones that needed to be updated are the constructors and get_boundary_of_a_cell and get_coboundary_of_a_cell.
inline |
Default constructor of Bitmap_cubical_complex_periodic_boundary_conditions_base class.
Gudhi::cubical_complex::Bitmap_cubical_complex_periodic_boundary_conditions_base< T >::Bitmap_cubical_complex_periodic_boundary_conditions_base | ( | const std::vector< unsigned > & | sizes, |
const std::vector< bool > & | directions_in_which_periodic_b_cond_are_to_be_imposed | ||
A constructor of Bitmap_cubical_complex_periodic_boundary_conditions_base class that takes the following parameters: (1) vector with numbers of top dimensional cells in all dimensions and (2) vector of booleans. If at i-th position of this vector there is true value, that means that periodic boundary conditions are to be imposed in this direction. In case of false, the periodic boundary conditions will not be imposed in the direction i.
Gudhi::cubical_complex::Bitmap_cubical_complex_periodic_boundary_conditions_base< T >::Bitmap_cubical_complex_periodic_boundary_conditions_base | ( | const char * | perseusStyleFile | ) |
A constructor of Bitmap_cubical_complex_periodic_boundary_conditions_base class that takes the name of Perseus style file as an input. Please consult the documentation about the specification of the file.
Gudhi::cubical_complex::Bitmap_cubical_complex_periodic_boundary_conditions_base< T >::Bitmap_cubical_complex_periodic_boundary_conditions_base | ( | const std::vector< unsigned > & | dimensions, |
const std::vector< T > & | topDimensionalCells, | ||
A constructor of Bitmap_cubical_complex_periodic_boundary_conditions_base class that takes the following parameters: (1) vector with numbers of top dimensional cells in all dimensions and (2) vector of top dimensional cells (ordered lexicographically) and (3) vector of booleans. If at i-th position of this vector there is true value, that means that periodic boundary conditions are to be imposed in this direction. In case of false, the periodic boundary conditions will not be imposed in the direction i.
inlinevirtual |
Destructor of the Bitmap_cubical_complex_periodic_boundary_conditions_base class.
inlinevirtual |
This procedure compute incidence numbers between cubes. For a cube A of dimension n and a cube B \subset A of dimension n-1, an incidence between A and B is the integer with which B appears in the boundary of A. Note that first parameter is a cube of dimension n, and the second parameter is an adjusted cube in dimension n-1. Given A = [b_1,e_1] \times \ldots \ [b_{j-1},e_{j-1}] \times [b_{j},e_{j}] \times [b_{j+1},e_{j+1}] \times \ldots *\times [b_{n},e_{n}] such that b_{j} \neq e_{j} and B = [b_1,e_1] \times \ldots \ [b_{j-1},e_{j-1}] \times [a,a] \times [b_{j+1},e_{j+1}] \times \ldots \times *[b_{n},e_{n}]s where a = b_{j} or a = e_{j}, the incidence between A and B computed by this procedure is given by formula: c\ (-1)^{\sum_{i=1}^{j-1} dim [b_{i},e_{i}]} Where dim [b_{i},e_{i}] = 0 if b_{i}=e_{i} and 1 in other case. c is -1 if a = b_{j} and 1 if a = e_{j}.
std::logic_error | In case when the cube B is not n-1 dimensional face of a cube A. |
virtual |
A version of a function that return boundary of a given cell for an object of Bitmap_cubical_complex_periodic_boundary_conditions_base class. The boundary elements are guaranteed to be returned so that the incidence coefficients are alternating.
Reimplemented from Gudhi::cubical_complex::Bitmap_cubical_complex_base< T >.
virtual |
A version of a function that return coboundary of a given cell for an object of Bitmap_cubical_complex_periodic_boundary_conditions_base class. Note that unlike in the case of boundary, over here the elements are not guaranteed to be returned with alternating incidence numbers. To compute incidence between cells use compute_incidence_between_cells procedure
GUDHI Version 3.0.0 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : MIT | Generated on Tue Sep 24 2019 09:57:51 for GUDHI by Doxygen 1.8.13 |
