Abstract simplex used in Skeleton blockers data-structure. More...
Public Member Functions | |
Constructors / Destructors / Initialization | |
| void | clear () |
| Skeleton_blocker_simplex (std::initializer_list< T > &list) | |
| template<typename ... Args> | |
| Skeleton_blocker_simplex (Args ... args) | |
| void | add_vertices (T v, Args ... args) |
| void | add_vertices (T v) |
| void | add_vertices () |
| Skeleton_blocker_simplex (std::string token) | |
Simplex manipulation | |
| void | add_vertex (T v) |
| void | remove_vertex (T v) |
| void | intersection (const Skeleton_blocker_simplex &a) |
| void | difference (const Skeleton_blocker_simplex &a) |
| void | union_vertices (const Skeleton_blocker_simplex &a) |
| std::set< T >::const_iterator | begin () const |
| std::set< T >::const_iterator | end () const |
| std::set< T >::const_reverse_iterator | rbegin () const |
| std::set< T >::const_reverse_iterator | rend () const |
| std::set< T >::iterator | begin () |
| std::set< T >::iterator | end () |
Queries | |
| int | dimension () const |
| bool | empty () const |
| T | first_vertex () const |
| T | last_vertex () const |
| bool | contains (const Skeleton_blocker_simplex &a) const |
| bool | contains_difference (const Skeleton_blocker_simplex &a, const Skeleton_blocker_simplex &b) const |
| bool | contains_difference (const Skeleton_blocker_simplex &a, T x) const |
| bool | contains_difference (const Skeleton_blocker_simplex &a, T x, T y) const |
| bool | contains (T v) const |
| bool | disjoint (const Skeleton_blocker_simplex &a) const |
| bool | operator== (const Skeleton_blocker_simplex &other) const |
| bool | operator!= (const Skeleton_blocker_simplex &other) const |
| bool | operator< (const Skeleton_blocker_simplex &other) const |
An abstract simplex is represented as an ordered set of T elements, each element representing a vertex.
The element representing a vertex can be SkeletonBlockerDS::Vertex_handle or SkeletonBlockerDS::Root_vertex_handle.
inlineexplicit |
Initialize a simplex with a string such as {0,1,2}
inline |
Add the vertex v to the simplex: Note that adding two times the same vertex is the same that adding it once.
inline |
inline |
inline |
inline |
inline |
Substracts a from the simplex.
inline |
Returns the dimension of the simplex.
inline |
Returns the first and smallest vertex of the simplex.
Be careful : assumes the simplex is non-empty.
inline |
Intersects the simplex with the simplex a.
inline |
Returns the last and greatest vertex of the simplex.
inline |
Remove the vertex v from the simplex:
inline |
Add vertices of a to the simplex.
| GUDHI Version 2.3.0 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : GPL v3 | Generated on Tue Sep 4 2018 14:33:00 for GUDHI by Doxygen 1.8.13 |
