Cech complex data structure.
More...
| | Cech_complex (const ForwardPointRange &points, Filtration_value max_radius) |
| | Cech_complex constructor from a list of points. More...
| template<typename SimplicialComplexForCechComplex > |
| void | create_complex (SimplicialComplexForCechComplex &complex, int dim_max) |
| | Initializes the simplicial complex from the proximity graph and expands it until a given maximal dimension, using the Cech blocker oracle. More...
| Filtration_value | max_radius () const |
| const Point & | get_point (Vertex_handle vertex) const |
template<typename SimplicialComplexForProximityGraph, typename ForwardPointRange>
class Gudhi::cech_complex::Cech_complex< SimplicialComplexForProximityGraph, ForwardPointRange >
The data structure is a proximity graph, containing edges when the edge length is less or equal to a given max_radius. Edge length is computed from Gudhi::Minimal_enclosing_ball_radius distance function.
- Template Parameters
| SimplicialComplexForProximityGraph | furnishes Vertex_handle and Filtration_value type definition required by Gudhi::Proximity_graph. |
| ForwardPointRange | must be a range for which std::begin() and std::end() methods return input iterators on a point. std::begin() and std::end() methods are also required for a point. |
◆ Cech_complex()
template<typename SimplicialComplexForProximityGraph , typename ForwardPointRange >
- Parameters
| [in] | points | Range of points. |
| [in] | max_radius | Maximal radius value. |
| ForwardPointRange | must be a range of Point. Point must be a range of copyable Cartesian coordinates. |
◆ create_complex()
| void Gudhi::cech_complex::Cech_complex< SimplicialComplexForProximityGraph, ForwardPointRange >::create_complex |
SimplicialComplexForCechComplex & |
complex, |
int |
dim_max |
inline |
- Parameters
- Exceptions
| std::invalid_argument | In debug mode, if complex.num_vertices() does not return 0. |
◆ get_point()
- Parameters
| [in] | vertex | Point position in the range. |
- Returns
- The point.
◆ max_radius()
- Returns
- max_radius value given at construction.
The documentation for this class was generated from the following file:
