Gudhi::Points_3D_off_visitor_reader< Point_3 > Class Template Reference
OFF file visitor implementation according to Off_reader in order to read points from an OFF file. More...
Public Member Functions
void init (int dim, int num_vertices, int num_faces, int num_edges)
 Off_reader visitor init implementation. More...
void point (const std::vector< double > &point)
 Off_reader visitor point implementation. More...
const std::vector< Point_3 > & get_point_cloud () const
 Point cloud getter. More...
bool is_valid () const
 Returns if the OFF file read operation was successful or not. More...
Detailed Description
template<typename Point_3>
class Gudhi::Points_3D_off_visitor_reader< Point_3 >
Member Function Documentation
◆ get_point_cloud()
const std::vector<Point_3>& Gudhi::Points_3D_off_visitor_reader< Point_3 >::get_point_cloud ( ) const
inline
Point cloud getter.
Returns
The point cloud.
◆ init()
void Gudhi::Points_3D_off_visitor_reader< Point_3 >::init ( int  dim,
int  num_vertices,
int  num_faces,
int  num_edges
inline
The init parameters are set from OFF file header. Dimension value is required and the value must be 3.
Parameters
[in]dimspace dimension of vertices.
[in]num_verticesnumber of vertices in the OFF file (not used).
[in]num_facesnumber of faces in the OFF file (not used).
[in]num_edgesnumber of edges in the OFF file (not used).
◆ is_valid()
bool Gudhi::Points_3D_off_visitor_reader< Point_3 >::is_valid ( ) const
inline
Returns
OFF file read status.
◆ point()
void Gudhi::Points_3D_off_visitor_reader< Point_3 >::point ( const std::vector< double > &  point)
inline
The point function is called on each vertex line from OFF file. This function inserts the vertex in the vector of points.
Parameters
[in]pointvector of vertex coordinates.
Point_3 must have a constructor with the following form:
template<class InputIterator > Point_3::Point_3(double x, double y, double z)
The documentation for this class was generated from the following file:
GUDHI  Version 2.3.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Tue Sep 4 2018 14:33:00 for GUDHI by Doxygen 1.8.13
