Gudhi::Persistence_representations::Vectorized_topological_data Class Reference
The concept Vectorized_topological_data describes the requirements for a type to implement a container that allows vectorization. More...
Public Member Functions
size_t number_of_vectorize_functions ()
std::vector< double > vectorize (int number_of_function)
Detailed Description
Member Function Documentation
◆ number_of_vectorize_functions()
size_t Gudhi::Persistence_representations::Vectorized_topological_data::number_of_vectorize_functions ( )
There are various ways data can be vectorized. This function give us the number of functions for vectorization provided by a given class.
◆ vectorize()
std::vector<double> Gudhi::Persistence_representations::Vectorized_topological_data::vectorize ( int  number_of_function)
This is a function to vectorize given container. The parameter of a function have to be between 0 and the value returned by number_of_vectorize_functions().
The documentation for this class was generated from the following file:
GUDHI  Version 2.3.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Tue Sep 4 2018 14:33:00 for GUDHI by Doxygen 1.8.13
