The concept SimplicialComplexForAlpha describes the requirements for a type to implement a simplicial complex, that can be created from a Alpha_complex.
More...
Public Types | |
| typedef unspecified | Simplex_handle |
| typedef unspecified | Vertex_handle |
| typedef unspecified | Filtration_value |
| typedef unspecified | Simplex_vertex_range |
| Iterator over vertices of a simplex. More... | |
| typedef unspecified | Boundary_simplex_range |
| Iterator over the boundaries of the complex, in an arbitrary order. More... | |
| typedef unspecified | Insertion_result_type |
| Return type of an insertion of a simplex. | |
Public Member Functions | |
| std::size_t | num_vertices () |
| void | set_dimension (int dimension) |
| int | dimension (Simplex_handle simplex) |
| int | assign_filtration (Simplex_handle simplex, Filtration_value filtration) |
| void | insert_simplex_and_subfaces (std::vector< Vertex_handle > const &vertex_range, Filtration_value filtration) |
| Inserts a simplex with vertices from a given simplex (represented by a vector of Vertex_handle) in the simplicial complex with the given 'filtration' value. | |
| void | make_filtration_non_decreasing () |
| void | prune_above_filtration (Filtration_value filtration) |
| Simplex_vertex_range | simplex_vertex_range (Simplex_handle const &simplex) |
| Returns a range over vertices of a given simplex. | |
| Boundary_simplex_range | boundary_simplex_range (Simplex_handle const &simplex) |
| Returns a range over boundaries of a given simplex. | |
| typedef unspecified Gudhi::alpha_complex::SimplicialComplexForAlpha::Boundary_simplex_range |
'value_type' must be 'Simplex_handle'.
| typedef unspecified Gudhi::alpha_complex::SimplicialComplexForAlpha::Filtration_value |
Handle to specify the simplex filtration value.
| typedef unspecified Gudhi::alpha_complex::SimplicialComplexForAlpha::Simplex_handle |
Handle to specify a simplex.
| typedef unspecified Gudhi::alpha_complex::SimplicialComplexForAlpha::Simplex_vertex_range |
'value type' must be 'Vertex_handle'.
| typedef unspecified Gudhi::alpha_complex::SimplicialComplexForAlpha::Vertex_handle |
Handle to specify a vertex. Must be a non-negative integer.
| int Gudhi::alpha_complex::SimplicialComplexForAlpha::assign_filtration | ( | Simplex_handle | simplex, |
| Filtration_value | filtration | ||
Assigns the 'simplex' with the given 'filtration' value.
| int Gudhi::alpha_complex::SimplicialComplexForAlpha::dimension | ( | Simplex_handle | simplex | ) |
Gets the 'simplex' dimension.
| void Gudhi::alpha_complex::SimplicialComplexForAlpha::make_filtration_non_decreasing | ( | ) |
Browses the simplicial complex to make the filtration non-decreasing.
| std::size_t Gudhi::alpha_complex::SimplicialComplexForAlpha::num_vertices | ( | ) |
Returns the number of vertices in the simplicial complex.
| void Gudhi::alpha_complex::SimplicialComplexForAlpha::prune_above_filtration | ( | Filtration_value | filtration | ) |
Prune the simplicial complex above 'filtration' value given as parameter.
| void Gudhi::alpha_complex::SimplicialComplexForAlpha::set_dimension | ( | int | dimension | ) |
Sets the simplicial complex dimension.
| GUDHI Version 2.2.0 - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. - Copyright : GPL v3 | Generated on Thu Jun 14 2018 15:00:55 for GUDHI by Doxygen 1.8.13 |
