Constructs strong witness complex for a given table of nearest landmarks with respect to witnesses.
More...
| Strong_witness_complex (Nearest_landmark_table_ const &nearest_landmark_table) |
| Initializes member variables before constructing simplicial complex. More...
template<typename SimplicialComplexForWitness > |
bool | create_complex (SimplicialComplexForWitness &complex, double max_alpha_square, Landmark_id limit_dimension=std::numeric_limits< Landmark_id >::max()) const |
| Outputs the strong witness complex of relaxation 'max_alpha_square' in a simplicial complex data structure. More...
template<class Nearest_landmark_table_>
class Gudhi::witness_complex::Strong_witness_complex< Nearest_landmark_table_ >
- Template Parameters
Nearest_landmark_table_ | needs to be a range of a range of pairs of nearest landmarks and distances. The class Nearest_landmark_table_::value_type must be a copiable range. The range of pairs must admit a member type 'iterator'. The dereference type of the pair range iterator needs to be 'std::pair<std::size_t, double>'. |
◆ Strong_witness_complex()
Records nearest landmark table.
- Parameters
[in] | nearest_landmark_table | needs to be a range of a range of pairs of nearest landmarks and distances. The class Nearest_landmark_table_::value_type must be a copiable range. The range of pairs must admit a member type 'iterator'. The dereference type of the pair range iterator needs to be 'std::pair<std::size_t, double>'. |
◆ create_complex()
The function returns true if the construction is successful and false otherwise.
- Parameters
[out] | complex | Simplicial complex data structure, which is a model of SimplicialComplexForWitness concept. |
[in] | max_alpha_square | Maximal squared relaxation parameter. |
[in] | limit_dimension | Represents the maximal dimension of the simplicial complex (default value = no limit). |
The documentation for this class was generated from the following file:
