Gudhi::skeleton_blocker::Skeleton_blocker_simplex< T > Class Template Reference
Abstract simplex used in Skeleton blockers data-structure. More...
Public Member Functions
Constructors / Destructors / Initialization
void clear ()
 Skeleton_blocker_simplex (std::initializer_list< T > &list)
template<typename ... Args>
 Skeleton_blocker_simplex (Args ... args)
void add_vertices (T v, Args ... args)
void add_vertices (T v)
void add_vertices ()
 Skeleton_blocker_simplex (std::string token)
Simplex manipulation
void add_vertex (T v)
void remove_vertex (T v)
void intersection (const Skeleton_blocker_simplex &a)
void difference (const Skeleton_blocker_simplex &a)
void union_vertices (const Skeleton_blocker_simplex &a)
std::set< T >::const_iterator begin () const
std::set< T >::const_iterator end () const
std::set< T >::const_reverse_iterator rbegin () const
std::set< T >::const_reverse_iterator rend () const
std::set< T >::iterator begin ()
std::set< T >::iterator end ()
Queries
int dimension () const
bool empty () const
first_vertex () const
last_vertex () const
bool contains (const Skeleton_blocker_simplex &a) const
bool contains_difference (const Skeleton_blocker_simplex &a, const Skeleton_blocker_simplex &b) const
bool contains_difference (const Skeleton_blocker_simplex &a, T x) const
bool contains_difference (const Skeleton_blocker_simplex &a, T x, T y) const
bool contains (T v) const
bool disjoint (const Skeleton_blocker_simplex &a) const
bool operator== (const Skeleton_blocker_simplex &other) const
bool operator!= (const Skeleton_blocker_simplex &other) const
bool operator< (const Skeleton_blocker_simplex &other) const
Detailed Description
template<typename T>
class Gudhi::skeleton_blocker::Skeleton_blocker_simplex< T >
An abstract simplex is represented as an ordered set of T elements, each element representing a vertex.
The element representing a vertex can be SkeletonBlockerDS::Vertex_handle or SkeletonBlockerDS::Root_vertex_handle.
Constructor & Destructor Documentation
◆ Skeleton_blocker_simplex()
Gudhi::skeleton_blocker::Skeleton_blocker_simplex< T >::Skeleton_blocker_simplex ( std::string  token)
inlineexplicit
Initialize a simplex with a string such as {0,1,2}
Member Function Documentation
◆ add_vertex()
void Gudhi::skeleton_blocker::Skeleton_blocker_simplex< T >::add_vertex ( v)
inline
Add the vertex v to the simplex: Note that adding two times the same vertex is the same that adding it once.
◆ contains()
bool Gudhi::skeleton_blocker::Skeleton_blocker_simplex< T >::contains ( const Skeleton_blocker_simplex< T > &  a) const
inline
Returns
true iff the simplex contains the simplex a.
◆ contains_difference() [1/3]
bool Gudhi::skeleton_blocker::Skeleton_blocker_simplex< T >::contains_difference ( const Skeleton_blocker_simplex< T > &  a,
const Skeleton_blocker_simplex< T > &  b
) const
inline
Returns
true iff the simplex contains the difference \( a \setminus b \).
◆ contains_difference() [2/3]
x
) const
inline
Returns
true iff the simplex contains the difference \( a \setminus \{ x \} \).
◆ contains_difference() [3/3]
x,
y
) const
inline
Returns
true iff the simplex contains the difference \( a \setminus \{ x,y \} \).
◆ difference()
void Gudhi::skeleton_blocker::Skeleton_blocker_simplex< T >::difference ( const Skeleton_blocker_simplex< T > &  a)
inline
Substracts a from the simplex.
◆ dimension()
int Gudhi::skeleton_blocker::Skeleton_blocker_simplex< T >::dimension ( ) const
inline
Returns the dimension of the simplex.
◆ first_vertex()
T Gudhi::skeleton_blocker::Skeleton_blocker_simplex< T >::first_vertex ( ) const
inline
Returns the first and smallest vertex of the simplex.
Be careful : assumes the simplex is non-empty.
◆ intersection()
void Gudhi::skeleton_blocker::Skeleton_blocker_simplex< T >::intersection ( const Skeleton_blocker_simplex< T > &  a)
inline
Intersects the simplex with the simplex a.
◆ last_vertex()
T Gudhi::skeleton_blocker::Skeleton_blocker_simplex< T >::last_vertex ( ) const
inline
Returns the last and greatest vertex of the simplex.
◆ remove_vertex()
void Gudhi::skeleton_blocker::Skeleton_blocker_simplex< T >::remove_vertex ( v)
inline
Remove the vertex v from the simplex:
◆ union_vertices()
void Gudhi::skeleton_blocker::Skeleton_blocker_simplex< T >::union_vertices ( const Skeleton_blocker_simplex< T > &  a)
inline
Add vertices of a to the simplex.
The documentation for this class was generated from the following file:
GUDHI  Version 2.2.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Thu Jun 14 2018 15:00:56 for GUDHI by Doxygen 1.8.13
