Gudhi::Minimal_enclosing_ball_radius Class Reference
Compute the radius of the minimal enclosing ball between Points given by a range of coordinates. The points are assumed to have the same dimension. More...
Public Member Functions
template<typename Point >
std::iterator_traits< typename boost::range_iterator< Point >::type >::value_type operator() (const Point &point_1, const Point &point_2) const
 Minimal_enclosing_ball_radius from two points. More...
template<typename Point_cloud , typename Point_iterator = typename boost::range_const_iterator<Point_cloud>::type, typename Point = typename std::iterator_traits<Point_iterator>::value_type, typename Coordinate_iterator = typename boost::range_const_iterator<Point>::type, typename Coordinate = typename std::iterator_traits<Coordinate_iterator>::value_type>
Coordinate operator() (const Point_cloud &point_cloud) const
 Minimal_enclosing_ball_radius from a point cloud. More...
Detailed Description
Member Function Documentation
◆ operator()() [1/2]
std::iterator_traits<typename boost::range_iterator<Point>::type>::value_type Gudhi::Minimal_enclosing_ball_radius::operator() ( const Point &  point_1,
const Point &  point_2
) const
inline
Parameters
[in]point_1First point.
[in]point_2second point.
Returns
The minimal enclosing ball radius for the two points (aka. Euclidean distance / 2.).
Template Parameters
Pointmust be a range of Cartesian coordinates.
◆ operator()() [2/2]
Coordinate Gudhi::Minimal_enclosing_ball_radius::operator() ( const Point_cloud &  point_cloud) const
inline
Parameters
[in]point_cloudThe points.
Returns
The minimal enclosing ball radius for the points.
Template Parameters
Point_cloudmust be a range of points with Cartesian coordinates. Point_cloud is a range over a range of Coordinate.
The documentation for this class was generated from the following file:
GUDHI  Version 2.2.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Thu Jun 14 2018 15:00:55 for GUDHI by Doxygen 1.8.13
