Skeleton_blocker_complex_visitor.h
1 /* This file is part of the Gudhi Library. The Gudhi library
2  * (Geometric Understanding in Higher Dimensions) is a generic C++
3  * library for computational topology.
4  *
5  * Author(s): David Salinas
6  *
7  * Copyright (C) 2014 Inria
8  *
9  * This program is free software: you can redistribute it and/or modify
10  * it under the terms of the GNU General Public License as published by
11  * the Free Software Foundation, either version 3 of the License, or
12  * (at your option) any later version.
13  *
14  * This program is distributed in the hope that it will be useful,
15  * but WITHOUT ANY WARRANTY; without even the implied warranty of
16  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
17  * GNU General Public License for more details.
18  *
19  * You should have received a copy of the GNU General Public License
20  * along with this program. If not, see <http://www.gnu.org/licenses/>.
21  */
22
23 #ifndef SKELETON_BLOCKER_SKELETON_BLOCKER_COMPLEX_VISITOR_H_
24 #define SKELETON_BLOCKER_SKELETON_BLOCKER_COMPLEX_VISITOR_H_
25
26 #include <gudhi/Skeleton_blocker/Skeleton_blocker_simplex.h>
27
28 namespace Gudhi {
29
30 namespace skeleton_blocker {
31 // TODO(DS): to be constified
32
37 template<typename Vertex_handle>
39  public:
41
42  virtual void on_add_vertex(Vertex_handle) = 0;
43  virtual void on_remove_vertex(Vertex_handle) = 0;
44
45  virtual void on_add_edge_without_blockers(Vertex_handle a, Vertex_handle b) = 0;
46  virtual void on_remove_edge(Vertex_handle a, Vertex_handle b) = 0;
47
52  virtual void on_changed_edge(Vertex_handle a, Vertex_handle b) = 0;
53
62  virtual void on_swaped_edge(Vertex_handle a, Vertex_handle b,
63  Vertex_handle x) = 0;
64  virtual void on_add_blocker(
66  virtual void on_delete_blocker(
68 };
69
75 template<typename Vertex_handle>
77 Vertex_handle> {
78  public:
79  void on_add_vertex(Vertex_handle) { }
80
81  void on_remove_vertex(Vertex_handle) { }
82
83  void on_add_edge_without_blockers(Vertex_handle a, Vertex_handle b) { }
84
85  void on_remove_edge(Vertex_handle a, Vertex_handle b) { }
86
87  void on_changed_edge(Vertex_handle a, Vertex_handle b) { }
88
89  void on_swaped_edge(Vertex_handle a, Vertex_handle b, Vertex_handle x) { }
90
91  void on_add_blocker(const Skeleton_blocker_simplex<Vertex_handle>&) { }
92
93  void on_delete_blocker(const Skeleton_blocker_simplex<Vertex_handle>*) { }
94 };
95
101 template<typename Vertex_handle>
103 Vertex_handle> {
104  public:
105  void on_add_vertex(Vertex_handle v) {
106  std::cerr << "on_add_vertex:" << v << std::endl;
107  }
108
109  void on_remove_vertex(Vertex_handle v) {
110  std::cerr << "on_remove_vertex:" << v << std::endl;
111  }
112
113  void on_add_edge_without_blockers(Vertex_handle a, Vertex_handle b) {
114  std::cerr << "on_add_edge_without_blockers:" << a << "," << b << std::endl;
115  }
116
117  void on_remove_edge(Vertex_handle a, Vertex_handle b) {
118  std::cerr << "on_remove_edge:" << a << "," << b << std::endl;
119  }
120
121  void on_changed_edge(Vertex_handle a, Vertex_handle b) {
122  std::cerr << "on_changed_edge:" << a << "," << b << std::endl;
123  }
124
125  void on_swaped_edge(Vertex_handle a, Vertex_handle b, Vertex_handle x) {
126  std::cerr << "on_swaped_edge:" << a << "," << b << "," << x << std::endl;
127  }
128
129  void on_add_blocker(const Skeleton_blocker_simplex<Vertex_handle>& b) {
130  std::cerr << "on_add_blocker:" << b << std::endl;
131  }
132
133  void on_delete_blocker(const Skeleton_blocker_simplex<Vertex_handle>* b) {
134  std::cerr << "on_delete_blocker:" << b << std::endl;
135  }
136 };
137
138 } // namespace skeleton_blocker
139
140 namespace skbl = skeleton_blocker;
141
142 } // namespace Gudhi
143
144 #endif // SKELETON_BLOCKER_SKELETON_BLOCKER_COMPLEX_VISITOR_H_
A visitor that prints the visit information.
Definition: Skeleton_blocker_complex_visitor.h:102
Abstract simplex used in Skeleton blockers data-structure.
Definition: Skeleton_blocker_simplex.h:50
Definition: SimplicialComplexForAlpha.h:26
Called when performing an edge contraction when an edge bx is replaced by an edge ax (not already pre...
Definition: Skeleton_blocker_complex_visitor.h:125
Called when an edge changes, during the contraction of an edge.
Definition: Skeleton_blocker_complex_visitor.h:87
A dummy visitor of a simplicial complex that does nothing.
Definition: Skeleton_blocker_complex_visitor.h:76
virtual void on_swaped_edge(Vertex_handle a, Vertex_handle b, Vertex_handle x)=0
Interface for a visitor of a simplicial complex.
Definition: Skeleton_blocker_complex_visitor.h:38
virtual void on_changed_edge(Vertex_handle a, Vertex_handle b)=0
Definition: Skeleton_blocker_complex_visitor.h:121
Definition: Skeleton_blocker_complex_visitor.h:89
GUDHI  Version 2.2.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Thu Jun 14 2018 15:00:54 for GUDHI by Doxygen 1.8.13
