Rips complex data structure.
More...
typedef boost::adjacency_list< boost::vecS, boost::vecS, boost::undirectedS, boost::property< vertex_filtration_t, Filtration_value >, boost::property< edge_filtration_t, Filtration_value > > | OneSkeletonGraph |
| | Type of the one skeleton graph stored inside the Rips complex structure.
| template<typename ForwardPointRange , typename Distance > |
| | Rips_complex (const ForwardPointRange &points, Filtration_value threshold, Distance distance) |
| | Rips_complex constructor from a list of points. More...
| template<typename DistanceMatrix > |
| | Rips_complex (const DistanceMatrix &distance_matrix, Filtration_value threshold) |
| | Rips_complex constructor from a distance matrix. More...
| template<typename SimplicialComplexForRips > |
| void | create_complex (SimplicialComplexForRips &complex, int dim_max) |
| | Initializes the simplicial complex from the Rips graph and expands it until a given maximal dimension. More...
template<typename Filtration_value>
class Gudhi::rips_complex::Rips_complex< Filtration_value >
The data structure is a one skeleton graph, or Rips graph, containing edges when the edge length is less or equal to a given threshold. Edge length is computed from a user given point cloud with a given distance function, or a distance matrix.
- Template Parameters
| Filtration_value | is the type used to store the filtration values of the simplicial complex. |
- Examples:
- Bottleneck_distance/alpha_rips_persistence_bottleneck_distance.cpp, Persistent_cohomology/rips_distance_matrix_persistence.cpp, Persistent_cohomology/rips_multifield_persistence.cpp, Persistent_cohomology/rips_persistence.cpp, Persistent_cohomology/rips_persistence_via_boundary_matrix.cpp, Rips_complex/example_one_skeleton_rips_from_points.cpp, and Rips_complex/example_rips_complex_from_off_file.cpp.
- Parameters
| [in] | points | Range of points. |
| [in] | threshold | Rips value. |
| [in] | distance | distance function that returns a Filtration_value from 2 given points. |
| ForwardPointRange | must be a range for which std::begin and std::end return input iterators on a point. |
| Distance | furnishes operator()(const Point& p1, const Point& p2), where Point is a point from the ForwardPointRange, and that returns a Filtration_value. |
- Parameters
| [in] | distance_matrix | Range of distances. |
| DistanceMatrix | must have a size() method and on which distance_matrix[i][j] returns the distance between points \(i\) and \(j\) as long as \( 0 \leqslant i < j \leqslant distance\_matrix.size().\) |
- Parameters
| [in] | complex | SimplicialComplexForRips to be created. |
| [in] | dim_max | graph expansion for Rips until this given maximal dimension. |
- Exceptions
| std::invalid_argument | In debug mode, if complex.num_vertices() does not return 0. |
The documentation for this class was generated from the following file:
